Question about NEC VT460 Multimedia Projector
NEC vt460 After opening the projecter i found the only visible damage was to what looked like a thermister on the power supply board but there were no values to be able to quote. Is it likely that replacing this will solve the problem or is it more likely that there is other damage.heres a screen shot of the component on the board. http://img393.imageshack.us/img393/9572/p1010005np2.jpg thanks in advance, mike
  • NEC Master
  • 5,568 Answers
It does in fact appear to be a thermistor and the TH1 board marking seems to confirm that.
What markings are on the component (it appears to be a power transistor of some kind) adjacent to it?
If we can find a standard part number for it and you own some kind of meter, perhaps we can either eliminate or identify it as the original culprit.
The failed thermistor is either acting as a temperature sensitive clamp to prevent lamp failure or regulates lamp intensity dependent on temperature.
Maybe an email to NEC would get you the value of it (TH1) since I suspect a schematic or parts list will be hard to acquire.
Posted on Jul 01, 2008
NEC LCD 4610 Screen black.
Possibly the replacement power supply may have failed.
Feb 02, 2014 | NEC Televison & Video
There is a red border around the projection
HI
your red LCD penal is not working suspected loose connector or faulty LCD panel or main Board
ANS BY
M.R. Mumbai & Dubai
Aug 31, 2010 | NEC VT460 Multimedia Projector
My projector can't on
I assume you mean it has no power? This is fairly common with the NEC VT460,VT470,VT595. The power board/Power Supply has failed. I can usually repair or replace the power supply for $170
If you're familiar with electronics you can try checking the main power fuse by removing all the screws on the bottom of the projector & taking the cover off. The fuse is located just next to the ac plug. Test it using a continuity tester with long testing probes. If it's ok then the power board is bad & needs repair.
If it's bad replace with the same type fuse. You can bring the fuse to Radio Shack for identification or look on the power board next to the fuse holder for fuse amperage.
If you would like a repair please contact me at PRMHELP@EARTHLINK.NET
Thanks & good luck,
Jim
May 18, 2010 | NEC VT460 Multimedia Projector
Alien shadow projected on screen
It may be go to damage bulb,replace it buy new one,
Jan 04, 2010 | NEC VT460 Multimedia Projector
My television quit working after a storm, it wasn't even turned on during the storm. the power on the set and remote does nothing. but it makes a sound when plugged in like it is turning on then nothing...
Ok, this was a direct hit in this case and you will defiantly need to replace the power supply board in this unit. the first thing that will happen during a direct hit is, the surge will run threw the power cord and travel threw the entire power supply circuitry, frying all circuits. this includes the main mother board as well. I recommend replacing the mother board and power supply board as well. this will restore your set to its original operational value. The mother board is commonly called the main control board.
please rate and god bless:)
Apr 02, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Where is it
No Sir, Main power supply has 2 portion, 1st is called primary and 2nd is called secondary. Primary power area is connected to ac oulet directly and secondry power area is isolated and source of power to projector circuits. Lamp power supply calls "Blast Power Supply" in projectors (Its very high voltage area). Please be careful while testing power supplies.
Jul 25, 2008 | NEC VT460 Multimedia Projector
1 second in betweent flash
Thats ok, In my openion, projector has power supply problem. Please open it and check fuses in secondry power area. Atleast one fuse is open there.
Nec vt460 projector pix in focus but red ghost around figures
This is a convergence problem that is not easily repaired by a homeowner. This unit should see a servicer.
Dan
May 29, 2008 | NEC Televison & Video
Problem on Picture
Pls check the RGB Panels opening physically. that doesn't seems to be a PCB fault.
Viren
Nov 26, 2007 | NEC VT460 Multimedia Projector
NEC VT460 Multimedia Projector Logo
91 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
