Question about D-Link DI 514 Wireless Router (DI-514)
Security connectivity issues
I have had it set to WEP enabled and have had no issues maintaining multiple concurrent pc's connection to the internet. I recently tried increasing the security to a WPA level. Upon doing so I could only maintain one pc connection. I returned it to its previous setting to confirm that the setting seemed to be the culprit. Do I need a firmware upgrade? Is there a setting I overlooked?
Thank you
    Scholar:
  • 51 Answers
Is the PC connection you're able to maintain once upgraded to WPA a PC that is physically connected to the router? if so, that would make sense because WPA (and WEP for that matter) are only wireless security protocols and have no protections for hard-wired connections.
In order to convert your system to WPA security, you must first make sure all of your hardware is WPA compatible (that isWPA Drivers are available for it).
For your PC wireless connection, if you're running Windows XP you can go to the microsoft website and download the WPA client. It is available in the Microsoft Knowledge Base Article 815485. install the update and reboot. you will then be able to enable WPA security on your client.
Then you'll possibly need to update the drivers for your hardware for WPA support (router, wireless NIC, etc) if they did not already come enabled.
next you get to configure the router for WPA. you'll want to make sure you're set to WPA with preshared keys (no authentication server required), use TKIP as the algorhythm, and leave group key renewal at it's default value. and of course Select a key that is not likely to be guessed. write the key down as you'll need to configure your NIC using it.
to configure your NIC, once you're in the configuration menu select WPA-PSK for your authentication, TKIP for the encryption mode, in data encryption set it to TKIP, and in the network key put the key you selected earlier.
At this point you should be able to access your wireless router (or other access point). These instructions were kind of generic since i do not have the specific router you're using available to me, but the settings i discussed should be pretty universal when it comes to WPA security.
Posted on Jul 01, 2008
My ds lite wont connect to our internet i have a wireless router the ds says the security settings are not supported by the nintendo ds
WPA and WPA2 are not supported by the DS Lite, only WEP and unencrypted wifi connections are. There is no known way at the moment to make the DS Lite support WPA of any form so your only three options are to go to WEP encryption, use no encryption (not recommended), or set up an adhoc connection on a computer with that is connected to your router that has internet connection sharing enabled.
Mar 10, 2011 | Nintendo DS Lite
This error message is typically caused by WEP Key issues. There could be one of 3 things wrong.
1. Check Nintendo's router info for special notes, if available, for your router.
  • Click here to go to our Wireless Router Configuration page.
  • Use the drop-down box on the left to select, if available, your router manufacturer.
  • Click on your router's model number, if available.
  • Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
2. Are you using WEP security on your router?
  • Log into the router using the default IP (consult your router's manual for assistance)
  • If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
  • If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
  • The WEP Key must be a Hexadecimal (1-9, AF, no other special characters or letters).
  • Verify they are using the WEP Key in the first (# 1) slot. Even though their router may have multiple slots, the Nintendo DS is only compatible with the WEP Key in slot # 1.
3. Check to see if your router is using MAC filtering.
  • Log into the router using the default IP.
  • Find the section for MAC Filtering (typically under "Security").
  • If MAC Filtering is on ( "enabled"), enter the Nintendo DS's MAC address to the list of approved MAC address. For info on locating the DS's MAC address, click here. (For assistance with locating the MAC Filtering section of your router's setup tool, please consult the router's manual or contact the manufacturer.)
------------ Also make sure you need to enable shared internet on your computer. Enable shared internet with windows firewall. For doing this go to START, then go to control panel, select network connections, right click on it and select properties for your wireless internet connection, then click on the check box "Share connection", then click ok, and its done.
Jan 12, 2011 | Nintendo DSi XL Burgundy
Wii Console: unable to connect to internet error code:...
Error Code: 52032 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. If your connection was working previously, try power cycling your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. (Some routers may lose their connection to the Wii console while it is in Standby or turned off for a period of time. Check with your router manufacturer's website for the latest firmware, as there may be an update that will help prevent this issue from occurring in the future.)
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
May 16, 2010 | Nintendo Wii Console
What is the pin of belkin G wireless router?
First connect your router to computer with ethernet cable.
Then you can access it with default link.
http://192.168.15.1 or
http://192.168.2.1
Type user as "admin" and password as "admin" or blank or "password" or 1234 then you can se configuration page of router go to wireless settings and enable WEP security add new code so you can connect with that code.
If you want to configure it you can do it with below method.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Save settings and restart router
Then connect internet service provider cable to router .Then you can use it wireless.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 30, 2010 | Belkin (F5D7230-4) Router (587009)
Won't stay connected
Check in the XBOX settings to see if the TCP/IP settings are 1500 or 1514. (1514 is the default for TCP/IP)
Did you go through the encryption settings for WEP? There should be a setting on the router that allows gaming to pass through it.
Also, if the XBOX is encrypted in WEP, what length of key are you using. WEP is naturally unsecure (about 10 minutes on the internet because it is a static key), but that's all it can do.
Also, if there is a firewall setting through the router, check to see that it doesn't scan encrypted connections. (This can be even in the internet security).
Outside of this, there is not much else that can be the problem.
It's either the router settings or the Internet security package that you installed.
Sep 13, 2009 | Linksys (WRT54GC) Router
Unable to use Wireless Security Option when using multiple PCs
Just try to enable your security in WEP mode instead of WPA mode and then try to connect,it should connect as WPA encryption is not supported by windows ME.
Jun 05, 2009 | Linksys WRT160N Wireless Router
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
Psp
The following items are generally required to set up to connect to a network.
  • A WLAN access point or a wireless broadband router
  • Settings for the access point (SSID, WEP key, WPA key, etc. as specified when the access point was configured)
  • A network device, such as an ADSL/DSL modem or a cable modem.
  • An account with an Internet service provider
Hints
  • An access point is a device used to connect wirelessly to a network.
  • A router is necessary if a PC and the PSP™ system will be connected to the Internet at the same time. A router is a device that enables multiple devices to be connected to one Internet line.
  • SSID, WEP and WPA keys are types of wireless network information. This information may be required when connecting to an access point or a router.
  • User is responsible for Internet service fees.
Example of a network configuration Network equipment connection and setup methods vary depending on the equipment used.
require001.gif Common settings hr1.gif You can create network settings for use in connecting to the Internet through an access point and save them on the PSP™ system. You can save up to 10 connections.
Setting methods may vary depending on usage conditions. The following is an example of commonly used settings.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the PSP™ system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings).
3.
Select [Infrastructure Mode].
4.
Select [New Connection].
5.
Select [Scan].
The system searches for nearby access points.
Depending on the model of PSP™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
standard001.jpg 6.
Select the access point that you want to use.
SSID is an identifier assigned to an access point. If you do not know the SSID or the SSID is not displayed, contact the person who set up or maintains the access point.
standard002.jpg 7.
Select the type of security that you will use.
The type of security settings required vary depending on the access point. For details on what type to use, contact the person who set up or maintains the access point.
standard003.jpg 8.
Enter the encryption key for the security settings.
The encryption key field displays eight asterisks no matter how many characters you enter as the key. For information on the encryption key, contact the person who set up or maintains the access point.
standard004.jpg 9.
Select [Easy].
Basic settings are set automatically.
standard005.jpg 10.
Enter a name for the connection.
You can choose any name for the connection.
11.
Check the list of settings.
standard006.jpg 12.
Save the settings.
13.
Test the connection.
If you select [Test Connection], the system will connect to the selected access point.
14.
Confirm the connection test results.
If the connection is successful, information about the network connection is displayed.
Hints
  • If the connection test fails, follow the on-screen instructions to check the settings. Network settings for the connection can be changed from the options menu. For additional information, refer to the instructions supplied with the network device and by your Internet service provider.
  • Depending on the access point settings, you may need to enter the system's MAC address to connect to the network. The system's MAC address can be checked under in_setting.gif (Settings) > in_pspset.gif (System Settings) > [System Information].
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
WLAN connection
make sure that your wireless network card works.go to the settings of your router and set: wireless network mode:802.11b(or what your car supports) wireless network name:name Wireless SSID Broadcast:enabled Security Mode:wep wep key:write something create a new connection to your laptop with the above settings
Oct 04, 2007 | Computers & Internet
Psp internet problem
You need to enter the wep key, ONLY if you have wep enabled on the wireless connection.
Sep 15, 2007 | Sony PlayStation Portable (PSP) Console
D-Link DI 514 Wireless Router (DI-514) Logo
191 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
