Question about ASUS P5K-V - Motherboard - ATX - iG33 - LGA775 Socket - UDMA133, Serial ATA-300 , eSATA - Giga...
New computer does not boot up
I just assembled a new computer. I switched it on and bootred up to the bios settings. Switched off again and does not want to boot at all . no beeps are heard since then.
  • 983 Answers
Enter in to the BIOS setup by pressing "delete key" or "F2 "
change for the boot device priority (boot device order) ..
make it in order something like removable disk,harddisk ,cd roms..
after that try booting it up ...
before that check whether the harddisk & other devices are detected or not in bios ...
if it is not detected then you went wrong in connecting some where ...
just make it sure & do it
any doubts you can reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Posted on Jul 02, 2008
Alarm beeps and orange light flashes when power is switched on.
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Feb 15, 2014 | HP Pavilion Computers & Internet
Booting up new motherboard
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
Jul 05, 2008 | ASUS P5PE-VM Motherboard
My desk top computer has booting problem
The F1 or F2 takes you into the BIOS setting.
The problem could be a flat BIOS battery and the Date & Time needs to be set to the current date & time.
Replacing the BIOS battery with a new one will fix this problem. When you insert the new battery go into the BIOS setting and set the Date & Time.
Dec 30, 2012 | HP Presario Computers & Internet
After post screen monitor goes into standby and cannot boot from dvd
Not picking up video card, or rather losing communications. Use VGA port if available on you card, and make sure monitor is set to same connection port.
Nov 11, 2012 | Computers & Internet
How do i disable the video on board in p4 motherboard
It depends on the BIOS manufacturer but usually you need to enter in to the BIOS settings to change the video settings.
Oct 28, 2011 | ASUS P5GL-MX Motherboard
Compaq Monitor WF 1907 immediately after the Desktop /Monitor (set at VGA) is turned-on gets stuck at the COMPAQ sign in the center and F10=SetUP, EXC=Boot Boot Menuplus F11=System Recovery all displayed...
Try using your windows cd to boot up the computer and if that does not work then you may need to reset the bios. Inside the case if it is desktop there is a way to reset the the bios. There is a jumper that needs to be switch then switched back that will reset the bios. If this does not work may need to get a new hard drive. The MBR ( Master Boot Record) may have been corrupted.
Mar 26, 2011 | Compaq Presario SR5712F PC Desktop
My laptop doesn't boot my windows 7 DVD please help me
This problem can be happen if DVD ROM of laptop is not working or BIOS setting is not set for booting from DVD drive. If DVD ROM is not working then change it. Go to BIOS setting and choose first boot device as DVD ROM if it is BIOS setting problem. This can solve your problem. It is always good to buy licensed copy of OS and other software.
Thank you..
Nov 11, 2010 | Computers & Internet
Hd103uj has stopped working in my external box so I swapped it with a drive in my computer but it wouldn't boot, I switched it back to the original and it booted no problem. I only used this drive a few...
Check the jumper settings on the new drive drive,it should be set to MASTER otherwise it will not boot. Also check your BIOS settings to insure that the computer is seeing the drive.
Jan 05, 2010 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
During loading of window drivers the machine shut off.
go into systen bios and set the default leave it there for a good duration doing notheing. see if the machine dies if not save the setting and reinstall using the Boot from CD.
DO not Boot from HD
try a different CD drive unit too.
Jul 27, 2009 | Computers & Internet
No beeps, No video but fans and lights come on...
Its the DG31PR bios!
Put a non 45nm CPU on it, update the bios to the latest one , put back your 45nm processor and all should work just fine....this board is awesome.
Cheers!
Apr 18, 2008 | Intel DG31PR Motherboard
ASUS P5K-V - Motherboard - ATX - iG33 - LGA775 Socket - UDMA133, Serial ATA-300 , eSATA - Giga... Logo
77 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
