When i turn my ps3 on it goes to a screen saying 'corrupt data on hard drive press to continue with restoring' then it restores to 100% then restarts, but then does the exact same thing and i cannot change the screen?
Re: When i turn my ps3 on it goes to a screen saying...
Take the hd out and try to reformat it on your computer.. if not try a different hd.. can be bought on-line for 25$ish..
THis should fix it.. if you download unsecured content this can happen!
You seem to have some corrupted data on the hard drive regarding downloads and firmware. No fear this is an easy fix. First off...shut off ps3 so that its in standby. (Red Light On). 2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will
beep as it turns on and then it will double beep. When you hear the
double beeps immediately take your finger off the power button (if your
system turns off before you get a double beep just try again and hold
the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the PLAYSTATION®3 System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the PLAYSTATION®3 System IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM I REPEAT CHOOSE RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading
something like "you have Corrupted System Data. Your PS will now
replace this data" Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3
with the original ones that are stored on your hard drive. In this
case, it replaced a corrupted driver for the blu ray drive thus fixing
my issue and hopefully yours!! This option will only replace all system
files thus saving you from loosing any data that's stored on your hard
drive. Again this option does nothing to your hard drive it reads a
file from the drive and rewrites it to the PS3 system. Hope this helps...it did for me.
Be sure to folleow these instructions to the letter, you could damage your PS3 if you choose the wrong option! I do not take any responsibility! Please proceed at your own risk! If you read and follow the instructions exactly you should not loose any data! Feel free to ask questions if you are confused so you don’t make a mistake!! Sorry, I had to say it, I don’t want anyone mad at me if they make a mistake, don’t back up their data and erase it, and then blame me…
The current version of the ps3 firmware has a “recovery console”. You access it by
1. Start with having the system in standby (redlight is on)
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
1. Restart System: Restarts the PLAYSTATION®3 System. 2. Restore Default Settings: Reset all system settings back to default. CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files. 4. Rebuild Database: Rebuilds the OS for the PLAYSTATION®3. 5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch. 6. System Update: Update the PLAYSTATION®3 System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive isoption 3: RESTORE FILE SYSTEM
After this, it is going to restart and bring up a screen reading something like “you have Corrupted System Data. Your PS will now replace this data” Then you choose continue and that should be it.
This option reinstalls the system files and drivers inside the PS3 with the original ones that are stored on your hard drive. In this case, it replaced a corrupted driver for the blu ray drive thus fixing my issue and hopefully yours!! This option will only replace all system files thus saving you from loosing any data that’s stored on your hard drive. Again this option does nothing to your hard drive it reads a file from the drive and rewrites it to the PS3 system.
Here is a video of the recovery screen. www.youtube.com/watch?v=m0SPmkV-jco If you want a more technical understanding of what this is really doing continue reading. DO NOT NEED TO READ THIS TO COMPLETE REPAIR. The PS3 does not boot from your hard drive as a computer does. It has a flash memory like a cell phone that stores all system files and system firmware updates that you get when the PS3 updates. This is why reformatting your hard drive will not fix your problem, none of the system files are stored on your hard drive (ex. XMB, system firmware, etc.) nor do they run from the drive. However, your hard drive does contain a full backup of your SYSTEM files and thus when you choose option 3: RESTORE FILE SYSTEM it rewrites the original system files from your drive (which aren’t corrupted) back to the flash
Try to restore file system on your ps3 or restore ps3 system. Here is how.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode). 2. Put out your usb cable for the controller and the controller itself (do not connect yet). 3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off. 4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button. 5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that. 6. After connecting the controller press PS button. 7. You are now in the recovery menu. 8. To fix the problem of corrupt data you can choose #3. 9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive. 10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Restore File System. If that do not work try Restore PS3 System. Follow this guide. Read carefully.
You Have A Critical Error Within The System Hard Drive A Basic Electronic Componant Restoration Understanding Won't Help You So if You Don't Have An Advanced Understanding Of Circutry Or Electronics Restoration You'll Need To Send It For Repairs Or Replacement
jvbeaudette
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
west_shelton
