Question about Asko W6021 Front Load Washer
Asko 7005 and washer 10505
I think the therm fuse blew out in my dryer...the power comes on and when i push the start button i hear clicking noises....i think the ventalation got blocked..how do i change the fuse out.
Also is it possible to change the outlet cord on the 10505 series washer asko? So it wall plug into the wall and not the dryer?
  • 725 Answers
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Posted on Sep 26, 2009
My asko dryer 7005 works the heating element but the drum d,not turn
broken belt , defective timer, defective board if electronic, defective push button start switch, defective cintrifugal switch in the motor itsself, defective motor, foreign object blocking fan motor in housing, stuck drum rollers.
Mar 02, 2012 | Asko Dryers
7005 dryer will not start when i push the start button
Welcome to FixYa.
I don't know how far you've gone since posting here four hours ago at FixYa but I can tell you 2 of the most likely reason your Asko 7005 dryer will not start.
The first place I'd direct you, would be at the back of the dryer to check the fuses, there are two 15A - 240V slo-blow fuses. In fact both possibilities will be confimed or dismissed at the back of the unit.
If you look at the back as I alluded to by the power cord you'll see two small gray disc/button looking items, these are the fuse holders. You should see this...
i.e.
**Be sure to turn off the power to the dryer or unplug it from the wall before performing any service suggested here please...safety first**
To access and check the fuses, you'll need to remove the holders. To do this requires only a flat screw driver, or even a butter knife and a multi-meter or "OHM" meter to check them.
(Alternately you can switch the fuse with a known good fuse to verify if it is blown )
Insert your tool of choice into the slot in the holder and turn it 1/4 turn counter-clockwise (right) and the holder should be in the position to remove...it may require some giggling to get it out as they have been known to get "stuck" from heat.
Once out this is what you should be presented with...
i.e.
If you remove this fuse from the holder and measure the continuity, you'll know if it is any good.
The other possibility I spoke of is the hi-limit cut out thermostat. It is also located at the back of the dryer.
This is what to look for...
Oct 02, 2010 | Asko T700 Electric Commercial Dryer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
Unable to locate any info on a model 10505 se # 982410041588
Hi, I may be mistaken but I don't think so, that number ( 10505 ) is for an Asko washer built in 1998, not a dishwasher. Do you require assistance with your washer ? I will watch for your reply. Macmarkus :)
Mar 17, 2010 | Asko Dishwashers
Asko dryer has no power.Washer ok
By-passed fuses,dealer said he's done hundreds.Saved me a service call.This is the 1st and only problem we've had in 10 years! We love our Asco.
Feb 16, 2010 | Asko Dryers
Asko dryer model#7005 when i start the dryer i push the start button and let it go it does not stay on. If i hold the start button down the dryer will stay running.
Hi There, Sounds like there is a relay switch that may be faulty, the power should latch on when you press the start button, I am unsure of this model type, but usually there is a small PCB inside the unit behind the facia, remove the top to expose it, and you can either replace the PCB or replace the relay the latter being cheaper but more work as you will have to reflow and solder the relay
Nov 27, 2009 | Asko Dryers
Asko dryer 7005 will not start. When I touched
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Nov 22, 2009 | Dryers
Start button does not work on our Asko t720 dryer
if you get a light on the main power switch, then it might be overheat cut-off switch wich has been activated. This is located outside on the back of the machine. a rubber button aprox in the middle, you must push this, and hear a 'click'. it might be a solution.
Jul 07, 2009 | Asko Dryers
Asko 7005
Go reset your circuit breaker. Even if it didn't pop out, reset it.
Oct 25, 2008 | Dryers
Asko t760 display panel
My Asko T761 had the same problem, power button lights up but the LCD panel if off. This is not the fuse becuase I replaced with "new fuse replacement kit" provide by Asko but this did not solve my problem. All I needed to do was press the "reset button".
Feb 08, 2008 | Asko T761 Electric Dryer
Asko W6021 Front Load Washer Logo
362 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
