Question about KitchenAid KUDS01DJ - Multiple Color Dishwasher
Dishwasher leaking on florr
When I started the dishwasher last night, after a few minutes I noticed a good bit of water leaking on the floor. I stopped it, drained it, and have not used it again yet. Any ideas?
  • 225 Answers
It could be:
a dirty door seal
a clogged pipe on the pressure sensor causing it to overfill
a genuine leaking hose
Much depends on where it is leaking from. The door seals can be cleaned with a detergent laden cloth, hard grime removed with a plastic scouring pad or a blunt knife (with care)
A clogged sensor pipe needs to be removed and cleaned out - access will most likely be from beneath. While you are there you can check the hoses for leaks too!
As a starting point I would put a kettle or two of very hot water and a generous dose of detergent into the machine and try to let it clean itself. While it is doing that try to spot where the leak is. There may not be one if it was overfilling.
I hope this helps.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please add a comment with more details so I can try to help you further. Cheers, D
Posted on Jul 01, 2008
I have a GE Potscrubber dishwasher which is about 13 years old. I recently experienced a problem when I ran the dishwasher I had water leaking onto my floor. In addition, the cycle had not used all the...
The pump seal may be the problem. There are a number of places on the net where you can get step by steps and the the parts to replace the seal. Some recommend just getting a new motor pump housing which is 150. I just purchased the impeller assembly (it has all you need) and it cost $25 with shipping. Only thing is I did not realize I also had a leak in the solenoid stem valve. Let me know if you need the link I was talking about.
Dec 08, 2010 | GE Dishwashers
I have a Frigidaire dishwasher that's just over 1 year old and I use it a couple times a week. I turned it on last night and went in another room. appox 30 minutes later my daughter came in and noticed the...
Someone squirted dish soap in there instead of regular dishwasher detergent...
You will need to manually rinse out the soap and use the right soap...
Sep 18, 2010 | Dishwashers
Dishwasher not getting water.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Nov 16, 2009 | GE 24 in. GSD2000Z Built-in Dishwasher
Our Kemore dishwasher is leaking water onto floor, and the water valve continues to pour water when machine was turned off, but is not leaking water now. There is also standing water at bottom of tub from...
you just need to clean the pump area in the bottom of your unit :)
try to take spray arm out if you can and then open pump cover clean it good but watch for broken glass in it ...and thats it :)
Aug 12, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Leaky Dishwasher
The dishwasher was installed with a defective fill valve or the valve was damaged during installation of the dishwasher.
Jun 23, 2017 | Magic Chef 24 in. DC4000 Free-standing...
Neff dishwasher continually draining
Update to my problems. It is now working. I removed the T20 tork screw housing the pump cover which is situated underneath the filter. I used a sponge and siringe to remove all water. And started the dishwasher a few times to spin the pump and flickout any excess water. I noticed some small bits of food which were removed and I cleaned all filters and put it back together. It didnt work staright away but the pump was not comong on as soon as the door was shut anymore. I did a reset and then selected a rinse programme and voila it worked! Tried a full wash cycle last night and it all seemed to be working fine......
Feb 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Indesit D61 Dishwasher element fault?
poss element or heater relay on the pcb.
Jan 19, 2008 | Indesit 24 in. D61 Free-standing...
Ultra Wash
Sounds like your not getting water to it. Turn on and let run for a few minutes then open door and check to see if you have water in it.
If not check to be sure water to it is turned on. Check float in front corner of dishwasher to see if moves freely up and down and that there is nothing underneath it. If these check ok you probably need a water valve.
Nov 03, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
Hotpoint dwf30 freestanding dishwasher
your leak might be caused by a faulty door far as your other problem try turning off the power at breaker for 30 sec. to reset cpu
Oct 24, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Neff dishwasher continuously attempting to pump out water
I have just encountered the same problem on my S5433 XO GB/13. Did you manage to get a solution.
Jan 17, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
KitchenAid KUDS01DJ - Multiple Color Dishwasher Logo
178 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
