Question about Epson Stylus C84 InkJet Printer
Epson C84 Could you tell me two things: 1. How do I clean the inkjets 2. How do I print a test page Thank you so much
Go to printers, right click on the printer icon, choose printing preferences, then click on maintenance. you will find everything you need there.
Posted on Jul 14, 2008
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 prints every other line.. Cleaned print heads and ran nozzle check...still same problem.
Your printer head may be booked. Follow the instruction given bellow:
1. Open printer cover and put off cartige from cartige chamber.
2. Take a plastic seringe with full of ink and fit it on head's stick. Then push ink carefully.
use this procedure one after another . I thing you may relive from your problem. thank you.
Aug 17, 2010 | Epson Stylus C84 InkJet Printer
C84 stylus - put new cartridges in and it doesn't print full text or all color
Did you use Original Epson Cartridge? I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Comments: Nov 12, 2009- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial " Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Nov 29, 2009 | Epson Stylus C84 InkJet Printer
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
Good Luck :0(
Asker's Testimonial
Comments:
Nov 12, 2009
- Funny. hahahahah,
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Pages are coming out completely blank...ink is fulll...i have cleaned the print head
I'm saying the same below!
By mclamemo on Nov 12, 2009 " " re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Help! +++++++++++++++++++++++++++++++++ I have learned from experience, that Epson2.gif does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Good Luck :0(
Oct 16, 2009 | Epson Stylus C84 InkJet Printer
Printer prints blank pages, have changed and installed new ink cartridges. wen through the head cleaning cycle bunch of times no luck. Any suggestions in fixing this?
Are you using Generic Cartridges? Pls See Below
Good Luck :0(
Oct 08, 2009 | Epson Stylus C84 InkJet Printer
Printer keeps printing lines across the page of 1
Width of head sprayer (head output) of black is about 1". Check nozzle. It might be some point of head spayer distort. See check nozzle ouput. There are tranversal and vertical lines that represent same point of head sprayer. Is the output perfectly straight and no clog at all? Do head cleaning procedure.
Aug 21, 2009 | Epson Stylus C84 InkJet Printer
Its not printing a full word, can't get a good nozzle check. Cleaning doese not help.
Print a test page. If you can't see everything clearly, clean the nozzles per the instructions. Run another test page. If not clear still, re-clean the nozzles another 2-4 times. If no good still, try replacing the print cartridges.
May 29, 2009 | Epson Stylus C84 InkJet Printer
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Printer not printing
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Nov 29, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
