Question about Gateway GT5408 PC Desktop
Gateway gt5648e desktop power
My pc was working fine. Clicked on a shortcut and computer powered off. Went to turn back on and will not. The light on the power switch does not come on, the fans come on for only a second then off, the keyboard lights flash for a sec when you push power switch. Does it need a new power supply? Please help. Thanks.
I had temporarily solved this problem on my PC. After much research I've learned that Gateway shipped these PC's with faulty bios. What you will notice is that your machine will "loud fan reboot" every hour like clock work. Either clock in manually or use your system tools to see the exact reboots and manually reboot a minute before it shuts itself down. This has worked for myself and many others on various boards if you google the problem.
Weird? Yes!! But it worked !!! 2 months reboot free.
Posted on May 05, 2009
    Guru:
  • 257 Answers
Do you know what your system is having the Processor error if you on the system the keyboard flickers and later go away but the fan also runs for seconds and later went off then what you have to do is to detached all components attached to your system then only the system unit alone .
Use a good power connector cable and a good constructed socket then put it on and wait and hear the sounds it brings and the signals or error is going show then if it comes on and go off remove the fan and replace with new one if the problem persist then change the processor with new one and then your system should be back to life and if anything happened then post your difficulties so i can help you. ok
rate this solution.
Posted on Oct 06, 2008
How to reset gateway gt5648e vista to factory settings
Full Factory Recovery explained starting at page 102 in the manual. Download & "File/Save As" to your documents folder... http://www.manualslib.com/manual/56706/Gateway-Gm5688e.html#product-GT5648E
Jun 30, 2014 | Computers & Internet
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Will 430 watt powersupply work in GT5648E?
Maybe the new Power Supply is bad. You did turn the O/I switch on the back of the Power Supply to I? O means off.
If it still does not work, try putting the old Power Supply back in just to see if it acts the same way. If so you have a motherboard issue. It's not uncommon on some computers that when the power supply goes bad, it takes the motherboard with it.
Apr 23, 2012 | Computers & Internet
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspire™ T180 PC Desktop
Binkin blue power light
Hold the reset button using a pen for 30 seconds then turn it off for 10 seconds.
Sep 07, 2009 | Gateway LX6200-01 PC Desktop
Computer won't turn on at all
I think ur power supply SMPS inside the systemneeds to be replaced...
Jan 03, 2009 | Gateway GX7018E PC Desktop
Gateway monitors not powering on
Do you get an Amber light on either monitor?
Jun 21, 2007 | Gateway FPD1950
Gateway GT5408 PC Desktop Logo
478 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
