A/c unit has burned 2 capacitors within 1 month. the fan motor is running, but the compressor does not turn on. the system has a hard start kit installed. a/c tech recommends installing new unit for around $1900. it is a york 2-ton about 4 years old.
  • 1 more comment
  • fry6920 Jul 01, 2008
    what causes this problem, and what is my best solution?
    a/c unit has burned 2 capacitors within 1 month. the fan motor is running, but the compressor does not turn on. the system has a hard start kit installed. a/c tech recommends installing new unit for around $1900. it is a york 2-ton about 4 years old.
    if the power supply is fine then what is the best solution, just replace the capacitor and hope that it does not burn out, or replace the unit?
    i'm still not sure what would cause 2 capacitors to give out?
    President:
  • 2,712 Answers
It could be that the capacitors themselves were of low quality / wrong specifications, or there is a power overload somewhere in the system that is causing the capacitors to go kaput.
If replacing the capacitor helps it run a bit longer, then go ahead and do that, since that would be the cheaper option. But I do recommend getting the unit checked throughly for any fauts in the mechanics or circuitry that could be causing this to happen frequently..
Posted on Jul 01, 2008
    Genius:
  • 2,028 Answers
I'm sure that your serviceman told you that this is an indicator that the compressor is going out. When the compressor starts to go, it labors to get that initial start, pulling more juice, in turn blowing a fuse or burning out the capacitor faster. At this point just enough to burn the capacitor, but not enough to blow a fuse. Eventually you'll start blowing fuses. In deciding whether to replace it, consider the costs of a newly installed compressor versus the cost of a new unit. Shop around, and don't be afraid to play one against the other. You'll be amazed how much their prices will come down.
  • 983 Answers
Capacitors burns out due to some overheating in the component ...
  • 6,487 Answers
Actually run and start capacitors do go bad. They are only good for so many starts and stops of the unit. There is no industry standard for how long they will last. If you replace the capacitor and the unit works you are OK.
I would also like to mention thgat some capacitors are better made than others. mant times manufactures will use the cheapest (cost effective brand) for there units when new to save cost.
Hope it helps.......
  • Mark Gil
    Mark Gil Jul 01, 2008
    Yes you really need to replace the capacitor...
    Master:
  • 848 Answers
Check whether your compressor is getting enough power supply .......because there may be a power problem existing in your ac since it is 4yrs old
  • gopinath pasupathy Jul 02, 2008
    try to replace the unit itself
    Novelist:
    Champion:
  • 230 Answers
Sounds like they did all that could be done. As long as they installed the right capacitor I will agree with this diagnosis to install a new unit. I don't know what you mean by "unit". 1900.00 seems a little low for a condenser and a little high for a compressor. But that is just me.
HVAC fan is on, but the compressor attempts but will not start
Sounds like you have a condensing unit that has a lock up condition; commonly known as "Locked Rotor'.
A simple step would be to be sure the compressor is cool.
Start the unit, and as it try's to start, bump the compressor on the shell sideways to jar it , with a rubber mallet.
If the compressor starts... it may or may not start again at one point.
You can try adding a start assist, or commonly known as a Hard Start Kit. It's simple and the two wires go on the Run Capacitor In parallel with the wires with the compressor wires.
Usually the capacitor has a C common ..F fan.... and M motor terminals . The start assist wires piggyback on Common C and M motor. NOT THE FAN side of the run cap.
http://www.grainger.com/product/SUPCO-Hard-Start-Kit-4E240
Apr 30, 2014 | Heating & Cooling
CONTACTOR RELAYCLOSE BUT LOOK BURNED , FAN MOTOR START , BUT COMPRESSOR MOTOR START AND STOP IMMEDIATELY. CONTACTOR STAY CLOSE BUT COMPRESSOR DON'T RUN.OR COME ON AND STOP IMMEDIATELY.
sounds like a locked rotor, did the compressor get hot? did you check max amps on the compressor when it attempted to start?compressors have thermal protection built into their windings, a switch that will open to protect the compressor, and if the rotor is locked, normally you have to replace it, you could try putting what is called a start assist capacitor on it (AKA hard start kit) I would recommend the two wire model, easy to install.
You will need to wait for the thermal overload to reset, turn power off to unit till you get the kit on there.
Jul 18, 2011 | Heating & Cooling
My ac central air is blowing air but not cold
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device known as a "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning compressor. Another good device is called a "5-2-1" kit.
Jun 22, 2011 | Goodman CKL36AR36 Air Conditioner
Running but no cool air blowing
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device that is called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems
Jun 15, 2011 | Weather King 10AJA3601AH Air Conditioner
AC is not cooling
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device that is called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Carrier 38CKC036 Air Conditioner
We have Goodman AC unit...not sure what kind. It has blown VERY cold until the last few days where it would stay a little above where I had it set. Then yesterday I realized it was incredibly hot. My...
If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems.
Jun 11, 2011 | Heating & Cooling
HI i think my split system compresser has locked up when the outdoor unit enguages it hums then the fan cuts in for 2 sec then it drops the curcit breaker i disconected the power wire to the compresser and...
Its quite possible it could be the start cap,(if the unit was running fine before) Your gonna want to check the connections to the cap first,(with the disconnect turned off first) If the connections are fine,you can install a booster capacitor To see if that won't kick it off.
Jan 25, 2010 | Heating & Cooling
I have an older Goodman CKB 18-1
FOR QUESTION 1: They do run independantly. What will happen when your compressor is running but your outdoor fan does not, the pressures in the system will go really high and compressor will overload. That outdoor fan is used to disipate all the heat that is transferred from the inside to the outdoor unit.
FOR QUESTION 2: If you hear humming it can be 2 things. FIrst one is that that capacitor went bad. Dependiing if its a dual run capacitor(which helps both compressor and fan motor) or they both have individual capacitors. The second would be a bad fan motor. OPen your service panel outside to the AC. Find your capacitor for you fan motor. if there are 2 , locate the one that goes to your fan motor. Check it out(if its blown physically youll will notice it like really bubbled, like swollen) then change itout. Or you will have a dual run capacitor that runs both compressor and fan motor. It will have the terminals marked (Fan, Common, Herm) Bsically check your capacitor mfd(micro fared rating, it will say on the capacitor what its rated) Get a multi meter and put in the "MFD' selection. Before you check any capacitor you have to discharge the the voltage charge it has. Use an insulated handle screwdriver and just place the metel part across the capacitor leads. Basicall short them out. Then proceed with checks...hope this helps( remember to always pull the disconnect out from the box outside to cut power)
Jul 30, 2009 | Goodman CLJ30AR32 Air Conditioner
We got an a/c central unit goodman modle ckl60-1 and a month a go it broke and the technician said that it needed a new capacitor and freon and about a week ago the unit broke again and the technician said...
When a compressor is has to start. 1. HAs it been off longer than five minutes. As a service tech when I run on to this problem I install a hard start kit and a time delay. The start kit helps the compressor to start under heavy load condtions. The timer helps the compressor to balance out before tryng to start. Have tech set at 5 minutes. I install hard start kits and time delays on all my change outs. Replace problem will go away. Thanks Rus
Jun 15, 2009 | Goodman CKL60AR60 Air Conditioner
Hard Starting Dometic Rooftop AC unit
Just add a$10:00 hard start kit to the compressor.
Sep 06, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
341 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
