Question about Whirlpool Microwave Ovens
Mt52 microwave rear fan pulley in white 2 inch dia approx melts on shaft and requires replacement problem is web sites do not show image and therefore can't be sure of purchase.! are service manuals available online ??
  • Whirlpool Master
  • 9,086 Answers
This is a UK model, so I assume you're in the UK.
I would call 0844 815 8989 Monday - Friday 8 - 5:30 or send Whirlpool UK an inquiry here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
Is there anew model that uses a 2 screw side plate instead of a 3 screw with larger dia. yoke screw
If you wish to get some details About microwave Oven working and troubleshooting ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 22, 2016 | In Microwave Ovens
Us lgservice com
Check the fuse inside the oven.. It is on a wire housed in a white plastic. Twist it and the fuse comes out. The fuse is about 1/8 inch dia. by 2 inch. Be careful to replace it with exactly the same rating.
Jan 14, 2014 | Microwave Ovens
Oven turns on but will not heat
Check the fuse. It is on a wire plastic fuse case colored white. Twist to open, replace a fuse 1/8 dia x 2 inch with an exact replacement. Be sure that the cover is placed back well when you are done.
Jan 08, 2014 | Microwave Ovens
Just installed a GE JVM1790 microwave/convection. Microwave works fine, but convection oven makes very loud noise
My bet would be that the convection fan blade is loose on its shaft or has some other problem.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions
here.
Oct 22, 2012 | GE JVM1790SK Convection/Microwave Oven
Tappan over the range microwave tmv151fs. keypad shows SE and none of the buttons respond to being pushed.
"SE" means you have a shorted membrane keypad.
There are three ways to fix this:
The cheapest but most difficult is to remove and replace the membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Here are the part numbers, which you can order from the Pros here (our favorite supplier) or via the Sears Parts Direct Web site.
MEMBRANE KEYPAD
5304456071 (black)
5304456071 (white)
You can replace the control panel frame, which comes with a new keypad already installed.
This costs is a little more, but is much easier.
CONTROL FRAME WITH KEYPAD
5304456078 (black)
5304456079 (white)
The simplest way of all is to replace the whole control box.
ENTIRE CONTROL BOX
5304456080 (black)
5304456081 (white)
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
Oct 18, 2011 | Tappan TMT104E1 Microwave Oven
I have a Westinghouse wall oven and grill in the Silhouette series (approx. 18 years old). Where would I be able to purchase a replacement oven light glass cover?
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 29, 2010 | Microwave Ovens
Microwave convection oven- convection oven will not heat and the fan makes a loud clicking noise.
It may be that the convection fan blade is loose on its shaft, which will keep the heat from getting out well.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
You can download GE owner's manuals and installation instructions here.
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
When i open the microwave door the fan turns on. it doesn't seem to be microwaving, just the fan.
You most likely have a bad door switch. Depends on how the switch is damaged, it may shows some melted spots where connector is on it and therefore connector will need to be replaced as well
Nov 20, 2009 | GE Microwave Ovens
Strange rattle when microwaving
Chances are the blade assembly has come loose on the shaft of the internal cooling fan.
This can be solved with a couple of drops of super glue at the spot where the blade and shaft meet, then allow it to dry for several minutes.
Then you'll see the cooling fan.
Please let us know what you find.
Dec 23, 2008 | Sharp R-1490 Microwave Oven
GE Microwave vent fan replacement.
The part # SMV-260UA runs just under $60 from SamsungParts, depending on which of three versions you choose. You can find them here.
And a simple Google search shows quite a few hits for "SMV-260UA" and they seem to run about $40, assuming the listings aren't bogus - as so many search results are.
I have a few "new old stock" and used vent & cooling fans here.
I would be happy to supply one whole or just the blades if you like.
Just tell me the dimensions: diameter of the shaft hole and the length and diameter of the "squirrel cage" itself and I'll see if one of mine would work.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
108 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
