Question about Uniden Cordless Phone
Dect6.0 27951 GE phone
The screen on my handset went blank. I took the battery out, waited a while and replaced it. It worked for 2 days and is blank again. I bought the phone in March, so it isn't old. Any solutions?
dadaslew
    Novelist:
  • 105 Answers
It sounds like the battery may be defective, since it is clearly not holding a charge like it should. If it is still under warranty (which it likely is having only purchased it in March), then you would first want to contact GE for assistance. They should be able to help you with replacing the battery or the handset if that is determined to be defective.
Posted on Jul 01, 2008
The photo slide show is now blank The photo show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed...
Welcome to Fixya
Try this procedure to drain the static energy of the phone.
1. unplug power from base
2. unplug phone connection from base
3. remove cover and battery from handset
4. wait 10 minutes
5. put battery back, reattach phone connection and power
Thank you for using Fixya!
Jul 22, 2011 | GE Lands Phones
The photo slide show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed the reset button, but it...
1/15/09
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
You can do this w/o the phone cord attached.
Dec 30, 2009 | GE Lands Phones
Blank screen on razr 3 cell phone
I bought this cell phone off ebay thru a hong kong dealer what a mistake. This is the second phone they shipped me but not without extra expense for me and now this phone screen went blank in 1 day after receiving it. I just plan on sending it back and filing a complaint on ebay.
Just beware!!!!!!!
Seems like these cell phones need to be RECALLED.
Thanks
Oct 25, 2009 | Motorola Cell Phones
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
1/15/10
To fix this issue:
1. Unplug the Unit
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
GE 27956 only produces white screen in photo frame.
I followed these steps that were listed, but it didn't work. Then I increased the time in step to an hour, and it worked
I called GE support. I was told
4. wait 10 minutes
It solved the problem.
Feb 20, 2009 | Lands Phones
Static in the GE 29460 GE-2
I have the same problem with my GE 29460 GE-2 phone. I took apart the handset and the source of the humming and static is a bad (cheap) microphone. I have swapped in a spare handset from another phone which works for the time being... it doesn't fit the phone cradle very well. When I find a junked phone (any wired phone would probably work) with a good microphone I may try soldering in the mike into the old handset... its only a 2 wire solder job. I'm PO'd at GE for making junk so I don't want to buy the parts for this, if I could find them.
Nov 06, 2008 | GE 29460GE2 Corded Phone
GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
Jul 19, 2008 | GE 25942GE2 Cordless Phone System
PHILIPS ID937 phone.
Fixed:) Ok so I bought 2 extension handsets from different people off of Ebay, both new. First one wouldnt register or would say incorrect pin (0000). So I tried the second one, same thing. Here is what I did: When attempting registering, make sure the handset is physically on top of the main base station, IE charging. Start the registration process on the handset and press-hold (dont let go) the locate handset button instead of press and hold for 3 seconds (like the manual says to). If that didnt work, I removed the batteries and tried pressing and holding the same button for 3 seconds, then release. Wait 10 seconds, then press and hold for 3 seconds. Repeat. If the handset timed out and went back to the main unregistered instruction screen. I took the batteries out and tried again. It was a bit of trial and error but each cycle I removed the batteries to reset the handset. First extension handset took 20 minutes of head scratching, the second 2 minutes. Hope this helps someone. The build and sound quality on these units are great, the tech support....not so much.
Apr 02, 2008 | Uniden Cordless Phone
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Uniden Cordless Phone Logo
168 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
