Question about Pioneer CDJ-1000MKII CD Player
The unit will no longer play when its in ''record'' mode. It plays fine in the ''CDJ'' mode but when i switch over, it completly stops. How do i fix this problem?
  • 515 Answers
That's a tough one. Could be one of many problems, or a combination of issues. There are various motors which control various functions of the unit, so if one of these went bad, it would cause this type of problem.
Unfortunately, it's not easy to diagnose, and you will need to take it to a qualified service center for repair.
- Davis
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.1200s.com
Posted on Jul 12, 2008
Hey! my CDJ is playing and stopping, playing and stopping not in any sort of pattern either. almost like someone is touching the top plate in vinyl mode. it happens aswell if you try and slow down the...
Hi, if you mean the fault occurs in the cdj vinyl mode and your cd dosent play... then it sounds like your jog wheel sensor membrane. but would have to be checked firstly by an engineer.
if you live in the uk then you can send your pioneer cdj for repair to www.audiovisualservices.info
Hope this has helped you.
Feb 14, 2011 | Pioneer CDJ-1000 CD Player
When my cdj 1000 is playing,it stops in about and hour in a half when I'm mixing,it just completely freezes.I tried using a cd to clean it ,but it keeps ejecting the cd.I'll let it set for about a half...
hii Brother,
can u do one thing, if you are sure open ur CDJ. If you have some type of BLOWER, and clean the compartment of CDJ too.
There may be dust or foreign particle in the compartment thats why
CDs keep ejecting.
If you cant open ur CDj pls take help of someone expert.
I hope this will work.
thx,
Djajay
Aug 24, 2010 | Pioneer CDJ-1000 CD Player
800 mk 1 plays in cd mode but once vinyl button is pressed play stops. even if I press the play button. The unit still jogs fwd and back just fine in vinyl. The case i use on occasion puts pressure(maybe...
You are almost certainly correct re "pressure switches"
Pioneer call this part "sheet switch" and it is a circular plastic "sandwich" of multiple contacts and when constant pressure is put on it, it tends to stick together giving the effect you are pressing it when you're not.
The part will cost you about £30.00 + fitting - unless you are confident enough to do it yourself
email me if you would like to order one. mail@technicsdjuk.com
http://stores.ebay.co.uk/methleykev
Jun 25, 2010 | Pioneer CDJ-800 Turntable
My Pioneer CDJ 800 MK 2 - will not play in the vinyl mode, the cue button is flashing _ if i take it out of vinyl mode it will play fine , do i need to reset it?
Does the unit play in vinyl mode if you turn the platter by hand?. If this the case the commom fault in the "sheet switch" which is under the platter and sensors the pressure when you press the platter.
The "sheet switch" and it is a circular plastic "sandwich" of multiple contacts and when constant pressure is put on it (i.e something is sat on it for a long time), it tends to stick together giving the effect you are pressing it when you're not.
May 14, 2010 | Pioneer CDJ-800 Turntable
Tape completely rewinds when I let off the foot pedal
Make sure the button for back space is not at max is the second button from the right side if problem don’t get fix unplug the pedal from unit and try to play and stop if unit work Ok the problem is your pedal. Needs to be replaced.
Apr 02, 2009 | Panasonic RR-930 Desktop Cassette...
Error on the vinyl mode will let me cue but not play
More than likely you have a bad switch, although this is not something that you could service yourself. I would suggest taking it to a service center in your area. Make sure they are Pioneer authorized, and know what a CDJ800 unit is!
- OPTiC
DJ Equipment Repair Videos
DJ Equipment Repair
DJ Equipment Sales
Pioneer Parts
Jan 16, 2009 | Pioneer CDJ-800 Turntable
CDJ 800 wont play when in vinyl mode
Well im having the exact same problem and cant for the life of me figure out why it wont work if you have a soulution please please please email me
gasoline@live.co.uk
Aug 25, 2008 | Pioneer CDJ-800 Turntable
CDJ 800 mk2. Will play audio cd fine but won't play mp3's
There is no easy fix for this. You will more than likely have to have the CD traverse assembly replaced - you could try a professional cleaning and alignment first - but ultimately, you will have to replace the cd assembly.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 06, 2008 | Pioneer CDJ-800MK2 Turntable
DEAD LEFT CHANNEL!!
The most common problem is a dirty record<>play switch inside the unit. Try this: Using a blank tape, press and release record/play buttons several times. This can clean the switch a bit. Then play a tape. If it fixes the problem, then you need to take the unit apart and use a plastic safe spray cleaner on the switch (Check at Radio Shack, their tuner cleaner Catalog #: 64-4315 will work fine). Spray it into the switch and then work the switch with the buttons several times.
Hope that helps...
Geno
Apr 04, 2008 | Audio Players & Recorders
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Pioneer CDJ-1000MKII CD Player Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
