Question about Microsoft Xbox 360 Console
PINK DISPLAY WHEN I TURN ON THE XBOX I THE DISPLAY IS PINK I CAN HARDLY SEE THE PICTURE EVERYTHING IS PINK!
  • lindzabelle Feb 22, 2009
    My screen also turns pink when I use my xbox 360. However, my display is just fine until I use netflix. I am able to fix the problem by turning off and on the t.v. while the xbox is still running. I was told that it was the fault of the t.v. and not the xbox. I was told that the t.v. was just not refreshing properly. Hope this helps.
That happened to me not too long ago, except the screen was green. after a while, I turned it on and there was no A/V! So now I'm sending it back to Microsoft.
Posted on Jul 02, 2008
My light on the grey power box is yellow and the xbox 360 wont turn on and i tried everything what do i do
Hello
ITs the three red dots of death , what i mean is they had that all over and had millions of people had to recall them, i guess your just getting crapy xbox's my friends xbox did that, he took to a shop to get it fixed, but they couldnt, so i guess your sol, get xbox 360 elite they hardly had any problems with those.
Welcome
Jul 05, 2010 | Microsoft Xbox 360 Console
Red light on consaole flashing
k this is either red ring of death or your x box just caught a mild case of pink eye. if all four little ring peices are red then you must send it in but if only 3 are then simply unhook everything, reajust your xbox replug then turn on this hould fix your problem.
Jun 22, 2010 | Microsoft Xbox 360 Console
Wont put out a picture or make sound when turned
turn off your xbox and switch the switch on the video/ audio chord and turn it back on. or just get a new audio/video cord
Nov 04, 2009 | Microsoft Xbox 360 Console
I have a Panasonic PT-47X54J tv, and I'm trying to hook up HDMI with my Xbox 360. I connect the cables, and the picture is pink, with a lot of pink lines going all the way across it, and the picture is...
are you sure the lead is ok .have you ever hooked up anything else to the hdmi socket before .you have to find out which is at fault tv or xbox or the lead..good luck
Sep 14, 2009 | Televison & Video
Pavilion dv6600 dimmed lcd monitor
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
var experts = [{ avatar:'/Uploads/Avatars/68F2C5C.jpg',userName:'MNfisherman',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.7%, 799 votes', userUrl:'/users/mnfisherman',solutions:2295,experience:'Experience: Have knowledge with just about anything that is electrical, mechanical, or electronical & more!',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/ABF4CAB.jpg',userName:'localwonder',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'90.7%, 1460 votes', userUrl:'/users/localwonder',solutions:2913,experience:'Experience: I have yrs of experience dealing with many situations.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'avid101',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.8%, 264 votes', userUrl:'/users/avid101',solutions:795,experience:'Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'adirondacktr',"memberSince":'July 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'86.0%, 108 votes', userUrl:'/users/adirondacktr',solutions:363,experience:'Experience: hands on experience,training, mechanically gifted,and favorite reading material is how to fix things',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/4FD9B30.jpg',userName:'venexcsd',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'87.2%, 197 votes', userUrl:'/users/venexcsd',solutions:526,experience:'Experience: 50 years in the University of Life, plus an electrical engineering and computer background. ',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/579A389.jpg',userName:'benwabnick',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'89.5%, 383 votes', userUrl:'/users/benwabnick',solutions:881,experience:'Experience: Been working as a computer technician for 10 years and have certifications in A+, Network+ and MCP',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/images/icons/noAvatar.png',userName:'justaskjoe',"memberSince":'January 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'86.8%, 964 votes', userUrl:'/users/justaskjoe',solutions:1787,experience:'Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/5446F1F.jpg',userName:'heavymetal77',"memberSince":'June 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'85.2%, 95 votes', userUrl:'/users/heavymetal77',solutions:311,experience:'Experience: I have a wide range of experience in many fields.',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/1B34289.jpg',userName:'taran_2005',"memberSince":'November 2008',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'87.9%, 392 votes', userUrl:'/users/taran_2005',solutions:1752,experience:'Experience: If you have the desire to repair, follow my steps and be happy!!!! ',brandType:0,brandName:'',brandIcon:'' },{ avatar:'/Uploads/Avatars/0915BCA.jpg',userName:'komguy',"memberSince":'May 2009',rankImage:'/images/icons/Guru_s_bl.png',rankName:'Guru',rating:'89.0%, 177 votes', userUrl:'/users/komguy',solutions:301,experience:'Experience: I have been a Canon certified warranty repairman for 4 years. Always on top 10 national list.',brandType:0,brandName:'',brandIcon:'' }] BRAND_ICONS_DIRECTORY = '/images/Brands_24x20/{0}.gif'; var ctrl_experts = new Fixya.TopExperts(experts,$('ancAvatar'),$('imgAvatar'),$('ancUserName'),$('spnMemberSince'),$('imgRank'),$('spnRank'),$('spnRating'),$('spnSolutions'),$('spnExperience'),$('imgPrev'),$('imgNext'),$('imgBadge'),$('spnBrand'),$('ancRating'),$('ancSolutons')); ctrl_experts.render();
Jul 09, 2009 | HP Computers & Internet
Was playing on cod5 when screen went pink and green. turned it off unpluged everything,set it up again turned it on and no picture at all and no sound
i had this problem...  ring ms and get the console repared  the problem is with the gpu becoming burnt out...
check out this tutorial if you can get an error code up  http://forums.xbox-scene.com/index.php?showtopic=484726
if you cant get an error code say to the people in the xbox call center you had an error code 74 as this is the code you would get for this
May 12, 2009 | Microsoft Xbox 360 Console
Pink Screen
This needs to be returned to the Vendor or Sony Direct for replacement
Jan 14, 2009 | Agfa Cyber-shot DSC-W150 Digital Camera
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Picture problem
i have vizio that turn on, but no picture, and the invarter light is on and it won`t turn off.
Oct 20, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
19inch acer
Check your cables and connections.
Oct 15, 2007 | Acer AL1716B 17" LCD Monitor
Microsoft Xbox 360 Console Logo
311 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
