posted by messercandy on Jul 01, 2008
material will not feed across pressure plate of my new home model sx 2122 sewing machine
Comment by messercandy, posted on Jul 02, 2008
Thank you that was extremely helpful
Candy
Candy
Best Solution
posted on Jul 01, 2008
This machine has a pressure regulator on the left side.You should look to see that it is not loosened. When you lift up on the presser foot it should have resistance.
Then look at the feed dogs to see that they are moving, Set the stitch length at 4 and turn the hand wheel. The teeth should move towards the back of the machine. They should also be slightly above the needle plate as they go back and below the surface of the plate as they come forward.
If they don't rise above the plate , remove the needle plate and clean between the slots of the teeth.
sewman7
sewman7
Rating Locked! (?) messercandy has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for New Home 2014LE Mechanical Sewing
Email this problem
Email this problem
Can you Help with these Sewing Machines problems?
New Home 2014LE Mechanical Sewing Machine
threads not catching and then...
the threads are not catching... Answer This...
Lost instruction book
Does anyone know where I can... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
