Question about Orion1934 19" TV
Orion TV 1934
Is this TV in Digital mode that will work after the change to digital? thanks
I have an orion tv and i lost my remote and i want to replace it with an rca remote. how can i do that/ and also i dont know where to find my part number so can you pliz help me?
Posted on Jul 04, 2008
Lost sound through tv/sat mode
Try unplugging all of the equipment for 30 minute to an hour, and see if this fixes it, otherwise, it sounds like the flickering power may have caused a surge in the circuitry of the equipment, causing it to short circuit the digital tuner in the TV.
Feb 23, 2008 | Pioneer VSX-D498 Receiver
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
I have comcast basic cable. Recently I have six channels (always the same ones) that don't have sound. All the other channels are fine. We have a small tv in the bedroom also connected to the cable and...
Try changing the audio settings in your tv. Sometimes changing from pcm to dolby digital or vice versa can get your audio back up on these channels. Remember some stations are broadcasting in digital pcm and or dolby digital. I would leave tv on pcm. If that doesnt work check to make sure your not in a second audio mode (meaning set is on sap) sometimes a customer will accidentally hit the sap button. Put unit on stereo setting
Oct 22, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Set my remote to my orin tv set
I HAVE A ORION TV 1934 19 INCH I LOST REMOTE BOUGHT A RCA REMOTE I FORGOTT MY TV CODE
Feb 28, 2010 | Orion1934 19" TV
Tv output in progress
Did you ever resolve the issue with the "tv output in progress" screen as we have exactly the same problem. Many thanks.
Sep 07, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
My tv wont turn on. I have a toshiba regza 47hl167 and when it is in power saver mode it will not turn on have to unplug it and plug it back in till it finally comes on then change the power mode off then...
yes he is right.the digital main pcb is the brain of the tv and has the microprocessor which
controls unplugging the tv and plugging it back in.you are resetting the micriprocessor which is part of the digital pcb.
Jul 17, 2009 | Toshiba REGZA 47HL167 TV
Orion television cannot access digital services
I found the solution on AV Forums. Here's the link:
http://www.avforums.com/forums/lcd-televisions/635155-orion-tv-products-help-advice.html#post6566313
Jun 20, 2009 | Orion STV2763 27" TV
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
Feb 15, 2009 | iLO IWT3206 TV
Orion1934 19" TV Logo
150 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
