Question about Sony FWD50PX2/S 50 in. Plasma Television
Connecting dvd? how do i connect my dvd player to the plasma screen. i have an input rgb component, but i can only hear sound when i attach the scart leadinto the tv, and the 15pin rgb wire into the dvd, there is no picture, what can i do to view picture?
    Problem Solver:
  • 5 Answers
If everything is connected and dvd player is on, make sure you have the proper input selected on the TV. Input2 on this model TV. Try switching between the inputs.
An important thing you need to do is set the RGB input signal from PC to YUV or you won't have a good picture. This is done through the menu system
Posted on Aug 09, 2008
How to connect dvd player to LG RZ-32LZ55 in LCD TV
This 'TV' is really more of a video monitor. It has one DVI input, 2 SCARTS (1 RGB); component video input; composite video input; S-video, and stereo audio and RF inputs. Best picture would be using the component inputs if your DVD player has the outputs. If not you'll have to consider the S-video or composite (yellow) plugs. (Neither is HD capable....)
Jan 20, 2015 | LG Televison & Video
How do I attach a combination VHS recorder/DVD player to my new Sceptre 19
The best way of connecting is an HDMI cable if both have this. If both have SCART then use a SCART cable. Using the RGB input is really old skool, you will need to use the TV controls to select that input because it won't select itself.
Dec 29, 2014 | Sceptre Televison & Video
The picture is blue when I play a dvd. I recently connected it to a new Vizio TV. The other tv it was connected to gave us a good picture.
Check your connections for faults, also some connections on TV's are for RGB inputs, so you might have to try another connector or if you can switch the DVD's output to RGB etc.
Apr 04, 2010 | GoVideo DVR4000 DVD Player/VCR
Jvc plasma monitor gmv42e can not get a picture just sond no scart so what do i do
I have just been given one of these, it not a TV, it is a monitor, and so does not have a TV tuner or a scart (it was made for professional use).
You need to plug it in to a DVD player/Freeview/Sky box using alternative means to a scart lead. You can do this by using a scart to 3 BNC lead and plugging this in where it says 'Component/RGB B'. This carries the picture, but not the sound. To get the sound you will need to plug a twin phono lead into the red and white audio plugs.
Alternatively, you can use the 'Video in' yellow socket to connect to connect to a DVD etc. The guy did this in Maplin's and it seemed to work.
JVC professional were really helpful on the phone, ask for their technical department, they can also email you the manual.
Sep 06, 2009 | JVC GM-V42 42 in. Plasma Television
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
How to connect a humax foxsat-hd to a panasonic dmr 75eb recorder,to a panasonic th42px60b plasma tv,also will i get better result using component cable instead of scart lead. please can you...
You plug the humax into the panasonic dvd recorder and then from the outputs of the dvd recorder plug it into the panasonic plasma inputs
Is component video better than RGB? Well, yes and no, RGB provides the widest bandwidth and is the best choice for connecting audio visual devices like a Freeview box, digibox or Sky+ box to your TV, home cinema or home theatre system. DVD is however different, to reduce the amount of storage required DVDs are recorded using component video, it is therefore better to connect a DVD player via a component video cable to your TV, plasma or LCD TV etc.
Thanks if you have any questions please do not hesitate to ask
Dec 02, 2008 | Televison & Video
Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Jun 10, 2008 | Televison & Video
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Connecting tv to dvd player
It should be fairly straight forwards.. Simply get the SCART to SCART Cable.. Connect up the Two, DVD to Screen, turn them on, selecting any input/outputs Format etc, setups from any Menus...then start player select "Play" & ya should see the Picture & hear the sound...
Aug 31, 2007 | Philips 30PF9946 30 in. HD-Ready Plasma...
Sony FWD50PX2/S 50 in. Plasma Television Logo
146 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
