Question about Hotpoint Washing Machines
F-04 flashing on my Hotpoint WT960 washing machine
    Genius:
  • 1,036 Answers
F04 is an error code for the pressure switch not sensing the water level.
This may be a faulty switch, or more likely cause is a damaged rubber pipe connecting it to the drum area.
To have a look, Turn off and unplug machine, turn off water inlet.
Move the machine out to ge access to the back.
Remove the top rear screws, and slide the top off.
The pressure switch will be connected to one of the small hoses. Check all the hoses for condition and chafing, and that they are still attatched. The pressure sensor woll be a small unit plugged into the end of one, with a hose going straight down past the normal water level - possibly down to the bottom pump area. It usually is connected to a small inverted empty canister.
If the connections and hose seem fine, you can test the switch by blowing hard into the end of the attatched hose (you have to take it off to test with hose attatched)
I can find replacement parts dealers for you if you specify your main town.
Thanks for using Fixya! - if this provides a solution, please take a moment to rate it as such. Thank you.
Posted on Jul 01, 2008
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
Hotpoint washing machine WT960 is flashing F-12
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODESAccording to hotpoint website
Nov 26, 2011 | Hotpoint Washing Machines
How do i reset my hotpiont ultima lcd wt960 washing machine?
I have a hotpoint wt960 i did 1 load of washing, turned it off. Put next load in then it would not turn back on. any ideas???
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing machine WT960 flashing F-09
hi F09 code indicates a communication failure between pcbs,ensure the appliance is disconnected from the mains,check connections on both top pcb and main pcb at the rear,then retry,if sympton still there then may require new pcb.
Aug 24, 2009 | Washing Machines
My machine is flashing F-01 Hotpoint ultima WT960
so is mine 3rd August 20:20. I hope it is ok because sods law my warranty has just expired!!!! What does F-01 mean?
Jul 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
May 25, 2008 | Washing Machines
Hotpoint wt960
Full manual can be downloaded from this link
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/ultima-7kg-lcd-wm-19505771900.pdf
Technical helpline will be able to tell you what F10 means
Apr 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
223 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
