Question about NexxTech DP3222 DVD Player
Nexxtech dp3222 dvd player
I have a disk stuck inside player. It wilnot eject. ALso, when I hit menu I get something that says INTERLACE. Neither the remote or the box will eject or load the disc.
    Sergeant:
    Champion:
  • 417 Answers
DISC IS STUCK U NEED TO OPEN DVD PLAYER REMOVE MANUALLY ITS REALLY EASY TO DO JUST TAKE THE SCREWS OUT TAKE LID OF REMOVE DISC THEN PUT LIT BACK ON PROBLEM SOLVED
Posted on Jul 02, 2008
My unit was doing the same thing. Sometimes It would load the disk and then stall. Sometimes it would load, start to play and then say "disk error." I pulled the unit apart, pulled out the dvd mechanical unit, and I learned much.
First, to get the disk out, there is a white plastic gear in front on one side. Turn it with the flat blade of a screwdriver in the proper direction and a white plastic bar on the bottom will start to slide, lowering the dvd so that it disengages with the top bearing. Keep turning the gear until you can pull out the drawer. Now you have the dvd.
Second, the main problem on my unit is that the led was not adjusted properly. If you look at the underside of the led unit you will see two adjustment pots. They don't really look like screws (more like a four leaf flower -brass colored) but a phillips screwdriver will turn them. I first turned the one furtherest from the center of the unit (when looking at the unit with the adjustment screws furtherest away from you, it was the one on the left) about 1/16 turn to the right. Things got a little better. I tried another 1/16 turn and it did not help so I turned it back.. Then I did the same thing to the other adjustment screw (1/16 turn to the right) and now I cannot get it to fail!
I do not know exactly what these adjustment screws do, but they probably increase the voltage on the led. Another site I found said that as the led gets older, it doesn't shine as bright, so increasing the voltage helps. However too much voltage will shorten the life of the led.
I don't know exactly how long this fix will last, or if my led will die from it, but I was at the point of buying a new unit if I could not fix this one.
And I am now praising God that it works!
Posted on Jan 03, 2009
I have a dvd stuck inside the player and when I hit the open button on the player and on the remote nothing happens. The screen on my TV says open but nothing is happening and it doesnt even do that much...
You'll have to take the case off.
Six screws hold the case on. UNPLUG the unit and take the back off. There's no other way but it only takes five minutes.
Mar 02, 2011 | NexxTech DP3222 DVD Player
Where can I find the remote for this device?
here you are
  • http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=NexxTech+DP3222+&uuid=12777825676710
feel free to rate the help
Jun 29, 2010 | NexxTech DP3222 DVD Player
Hi, I need a 5 digit remote control code for a Nexxtech DVD player with 5.1 speakers. Thank you.
Using only the remote control do the following: open tray, then press on the remote, stop-2-3-7-9, press arrow down until 0, then press OK.
Jan 22, 2010 | NexxTech DP3222 DVD Player
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
Try a Laser Lens Cleaner disc.
It is a CD with brushes on the bottom to help clean the laser lens (used for reading discs).  It can be found cheapest in grocery stores, then office supply stores, and finally most expensive in electronics stores.  It will usually run you about five to ten dollars,and can be used multiple times on any disc drive.
Aug 13, 2008 | NexxTech DP3222 DVD Player
Open tray, press on the remote, stop-2-3-7-9, press arrow down until 0 and press ok.
Make shure you put TV TYPE --> ntsc in the general setting
I tried this (on a multisystem set that can be "made to think" that it's a PAL or NTSC set as the case may be) and it worked. The Nexxtech DP3222 and the Entiveo DP3220 are basically the same unit except that (a) the hack for the Nexxtech doesn't require resetting every time you turn the unit on and off, unlike the Entiveo (this is really annoying) and (b) you can set the Nexxtech to multisystem, NTSC, or PAL standards, whereas the Entiveo is NTSC-only, but (c) the fast-forward on the Nexxtech is somewhat less intuitive than on the Entiveo (involves holding a button down). All in all, I prefer the Nexxtech, if only because it is more easily hackable. And I would have sworn that the Nexxtech had a blue screen saver on it before I started hacking it, because now it has a really gross-looking black-and-white screen saver. But I don't care about screen savers as long as the unit does what I want it to do.
Jan 28, 2008 | NexxTech DP3222 DVD Player
COLOR IMBALANCE
go to setup menu;under video out-set to yuv--problem solved!
Ron
Dec 27, 2007 | NexxTech DP3222 DVD Player
Freezing
damaged or dirty disc-clean or replace
ron
Remote code #
I have just bought a GE Universal remote control and after playing with the codes and my Nexxtech DP3222, I have found the working code for the player. The code from my GE Universal 24921 for the DP3222 is 0956. The remote is sold in Walmart for a cheap price of US$4.96. I hope this info helps.
Nov 15, 2007 | NexxTech DP3222 DVD Player
Nexxtech DVD Slimline model DP3222
Could be an open internal fuse or power supply failure
Jun 04, 2017 | NexxTech DP3222 DVD Player
NexxTech DP3222 DVD Player Logo
141 people viewed this question
Top NexxTech Televison & Video Experts
jasbo
jasbo
Computer Repairing
Computer Repairing
Tygh Duval
Tygh Duval
Are you a NexxTech Televison and Video Expert? Answer questions, earn points and help others
