Question about Zanussi FJS1225W Front Load Washer
Removal of drain pump
I need to change the pump, it seems that it just pulls of as I cannot see any specific fixings. Can anyone tell me if all you need is brute force and ignorance to remove this from the housing, or am I missing a fixing somewhere? I am reluctant to use too much force as it is a plastic housing.
  • Rab2 Jul 02, 2008
    I will try undoing the screws, this looks like the answer, I may have to upgrade the rating! Thanks!
    President:
  • 1,462 Answers
There are two clips underneath cabinet base. difficult to remove and difficult to replace.
an alternative way but a bit fiddly, is to undo the 3 screws that hold pump to pump hosing - that is the way i always do it
Posted on Jul 02, 2008
Hoover top loader 750lc about 8 years old
Hi just read your posting.Now the only way to drain your machine if it is not draining is to do it by hand with a small pot or bucket. Do you hear a small click when you close the lid slowly?If you do then that is the lid switch.It will not drain if your lid switch is not activating.Did you wash a big load before the problem started?Also could be a faulty or jammed drain pump.I can guide you throe the removal of the pump to see if it is the problem if you have some tools available.Please reply after you have tested the lid switch and I can guide you throe the rest of the repair if needed.
Jun 05, 2010 | Washing Machines
How do i change the water pump on a 1999 2.5 v6 chrysler sebring?
Removal:
Drain cooling system, remove the timing belt if necessary. Remove water pump mounting bolts. Separate water pump from water inlet pipe and remove.
Inspection:
Replace water pump if it has damage or cracks to pump body. Check the shaft seal for any leaks as evidence by traces of coolant from vent hole. Check for any impeller rubbing inside pump, and for loose or rough bearings.
Installation:
Clean all gasket and "O" ring surfaces. Install NEW "O" ring on water pipe (wet "O" ring with water to aid assembly). DO NOT allow oil or grease to contact "O" ring. Install NEW gasket on water pump, and install pump inlet opening over water pipe. Install pump-to-block bolts and tighten to specification 18 FT. Lbs. (25n.m). To complete installation, reverse removal procedure.
Hope this helps :)
Oct 19, 2009 | 1998 Chrysler Sebring
I have the same problem
I had the same problem, I changed the water discharge pump and the drain problem was fixed. I still have the loud sound during the wash cycle but it does not coincide with the drum movement. I think a will pull the wash pump to check for lint buildup. people cleaning the lint trap will avoid alot of unnecessary headaches.
Jun 23, 2009 | LG WM-3677HW Front Load Washer / Dryer
Change powers steering pump
Hi, this is a step by step guide that will help you within your replacement of this device.
Step1
Loosen the drive belt and slip the belt over the pulley. Use a suction gun to **** out as much power steering fluid as possible. Place a drain pan under the pump and disconnect the lines and fluid return hose. You may need to remove the air cleaner housing to access the return hose. Allow everything to drain completely.
Step2
Cap the ends of all the lines to prevent leakage. Remove the mounting fasteners and detach the pump from the engine. You should be able to pull it free from the car completely and take a moment to inspect it and see what went wrong. You could then prevent the demise of the new power steering pump by addressing the source of the problem.
Step3
Measure how far the pump shaft protrudes from the face of the pulley hub, if it is necessary to remove the pulley to access the pump, as is the case with some engines. This assembly will need to be reinstalled to the correct positioning after the new pump is installed.
Step4
Install the new pump using the reverse removal procedure and make sure all fasteners are tightened securely. Also, take a moment to bleed the power steering system according to the directions in your repair manual. For specific instructions on the reassembly of some items during this process, consult your repair manual as each engine has its own specifications.
Please rate and have a great day:)
Apr 23, 2009 | Oldsmobile Intrigue Cars & Trucks
Zanussi DCS12w Not draining - Pump location needed.
It is inside the cabinet of the dishwasher, pull it out if build in to see the pump.
Apr 11, 2017 | Zanussi 18 in. DCS12W Free-standing...
LG WM1832CW Drain Pump
i drained it first with the pull out hose in the access panel on the bottom left. i tilted the washer back to remove it from the bottom.
Jun 17, 2008 | LG WM-1832C Front Load Washer
Slow or no drain from Kenmore HE3t washer
yes its possable take the hose off of the bottom of the tub and feel up in there to see if you can find it and check the hose its self lots of times you can squeeze it and tell .If its under the tub that would explain it working sometimes and not others.as it would depend on the position of the obstruction when the unit goes into drain i can be more specific if i have the answer to my questions
Mar 15, 2008 | Washing Machines
Draining issues
I just fixed a similar problem on my Samsung WF337 The machine was making a grinding noise during a wash cycle. After entering 'service mode' (see the "Washing Machine Technical Information booklet that came with your machine) and testing the drain pump operation I determined that the pump was the source of the noise. Eventually I found that a nickel had worked it's way into the drain pump. The manual does not address how to access or clean the pump so I thought I would post instructions.
  • Unplug the machine and turn off the water supply.
  • Remove the silver back panel by taking out the two phillips head screws, pushing the panel up, then pulling out on the bottom.
  • Under the tub, you will see the pump with two hoses attached. The black hose is the inlet from the tub and the white hose is the outlet to the standpipe
  • Using a cup and/or a towel to catch excess water, remove the hoses by squeezing the spring clamps and sliding them aside (slip joint pliers make this easier) then pulling the hoses off of the fittings on the pump.
  • If you need to take to pump out: Remove the three bolts (12mm hex head). I used a 1/2" drive ratchet with a 6"extension.
  • Unplug the power connector from the pump.
  • You can now lift the pump assembly out of the machine and remove any obstructions. To get the coin out, I had to shake the pump a few times and reach in with my finger to dislodge it.
  • And as always installation is the reverse of removal. Don't forget to reconnect the power cable to the motor and turn the water supply back on.
Jan 04, 2008 | Samsung WF337AA Front Load Washer
My washer/dryer is not draining properly.
If the pump is not draining, either the drain filter screen is clogged with debris, the drain pump is jammed by foreign debris or the drain pump itself has failed.  More than likely something is clogged in the filter screen or a sock is jammed up inside the drain bellows tube just before the filter.  Pull the drain filter screen out and look up the hole to see if there is any material stuck inside.  Usually that's the problem.
Nov 19, 2007 | LG WD-3243RHD Front Load Washer / Dryer
Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Sep 12, 2007 | Kenmore 22422 Top Load Washer
Zanussi FJS1225W Front Load Washer Logo
174 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
