I just bought a new computer but I want to stiil use my old one. How do I hook both up to my comcast cable conection?
  • 282 Answers
You should have a router so that you can connect 2 or more computers..you can use linksys,netgear,dlink..
Posted on Jul 01, 2008
Hook up netflix
Get a Roku streamer. It had an HDMI out as well as a composite cable so it will even work on older tv's You'll need to have a fast internet connection and a wireless capable router.
Dec 30, 2013 | JVC Televison & Video
I see that people are asking about driverss for the RCA dcm425 cable modem. I just bought a new computer, and I connected it to the my old dcm425 modem through a router and it works just fine. I didn't...
The trick about all this is that the software does not configure the computer, but the modem.
So once it has been configured through a computer then plugged to a router, any computer plugged to the said router will have access to the Internet.
The whole process of installing/configuring will happen if you replace the old modem and/or plug a new computer directly to the modem.
May 07, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have Windows 7 with service pak1 I have a cavalry CAXB3700 external hard drive. When I hook it up my computer it won't respond. I used a SATA and USB cable to try to conect to it and it stiil wouldn't...
Then it's most likely dead. To confirm that try to connect it to another MAC or Linux pc - if it's still not recognized then you will know for sure.
Apr 30, 2011 | Computers & Internet
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like Remotes.com to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Significant volume decrease when using Comcast cable box
This low audio problem happened to me suddenly yesterday. I powered off over night - no change. I plugged the A/V cables into a second TV - no change. I called Comcast - problem solved.
Tap these buttons on the remote;
May 16, 2009 | Panasonic Viera TC-L37X1 37 in. LCD HDTV
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
Cannot connect to the internet
Are you running the setup disc provided by comcast to get your email setup?
If you are , you do not really need that disc as it provides useless and often outdated junk on the disc. You should be able to surf the internet by plugging in your Ethernet Cord into the laptop with no problem.
On the issue of the Comcast user name and password, this was originally used at the original configuration of the modem when it is wallgardened.
You can always call Comcast and have then activate the modem for you. You'll need the Mac address at the bottom of your modem to activate it over the phone.
Online Activation usually requires your customer account number. But since it looks like you do not have this data, you will need to call them directly.
Aug 21, 2008 | HP Pavilion dv6000z Notebook
New laptop computer internet hook up
make sure everything (hardware/software) are in good working condition i.e properly pre-installed, then click on start, and interet connections, the wizard will ask you on how you intend to connect to the internet, just make sure you choose the correct options and off you go. you'll be on. good luck.
May 24, 2008 | Internet Compaq Evo N600C Laptop
Compaq was bought with msn companion service required
This is where you should be in contact with Comcast Tech Support 1-888 262-6300.
The INSTALL tech should have had you on-line before he left.
You need to conect your TV/Computer Cable to a Cable modem and a CAT 5 cable to your NIC (Network Interface Card)
All the lights on the modem should be on except the TEST light and the DATA light should be blinking.
You may have OLD drivers for the Cable modem, download those from another computer from the modem MFG.
Nothing else is required.
Dec 02, 2007 | Compaq iPAQ Home Internet Appliance IA-1...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
