Question about Belkin (F5D7231UK4) Wireless Router
Belkin router I have comcast cable connection it works when I plug line direct to computer connects. When I plug cable to router in cant find server? THIS ROUTER WAS USED WITH A CLEARWIRE CONNECTION IT WORKED FINE. THANKS
  • 137 Answers
You need to access router configuration page and have it get an IP from Comcast DHCP server.
Posted on Jul 01, 2008
The globe light is blinking. We can connect to Belkin but page not found comes up. The message that comes up says IP address does not match. We have 3 laptops, and none of them are allowing us to have...
  • Connect your computer directly to your cable or DSL modem. If you see a log-in screen for your Internet Service Provider, make a note of the user name and password.
  • Unplug your router and your cable or DSL modem.
  • Plug your modem to your Belkin router's "WAN" port. Connect your computer to one of your Belkin router's numbered ports.
  • Turn on in your modem and wait 10 seconds. Plug in your router and restart your computer.
  • Select "Start," then "Control Panel" and then "Network Connections." Right-click "Local Area Connection" to bring up your network connection properties.
  • Click "Internet Protocol (TCP/IP)," then "Obtain an IP Address Automatically" and then "Obtain DNS Server Addresses Automatically."
  • Open your web browser. If you are prompted for a user name and password, enter the information you recorded in Step 1
  • Dec 29, 2010 | Belkin F5D8236-4 Router
    Using the Belkin model f7d4302 for my PC (Processor: AMD Athlon II x215, 2.7 Ghz; 6 gigs of Ram on 64 bit system utilizing the Windows 7 operating system). Unable to connect directly to my modem (Comcast...
    Please follow the below steps,
    (1) What type of cable you are using between your Belkin Wireless Router. If you are using a cross cable which I suspect then replace it with a straight cable. You can easily get it from Computer hardware stores and sometimes in super markets. If you do not know how to check weather a cable is straight or cross please look at the connectors of both sides of the cable from downside up. If the position of small tiny colorful wires are identical in both connectors than it is straight which we need. If the position is not identical than it is cross cable and we do not need it. It will not work properly for you.
    (2) You should set the IP address to automatic in My Network/Network properties.The same for DNS.
    (3) You should know the IP of the Belkin Wireless router and you should be able to ping it with the cable on.
    This much configuration is required from the PC side.
    (1) If you look carefully around the Belkin Wireless router you will find a pin whole. This pin whole is used to reset the settings to default by poking a pointed object like a pin. Make sure the wireless router remains powered on during this.
    (2)After this if you still face connectivity problems. Try replacing with another Wireless Router just to check if the connectivity or QoS improves. If it does, you can be sure that the problem is with your Belkin wireless router.
    Good Luck!
    Sep 25, 2010 | Computers & Internet
    I have a Zonet Router that I am hooking up to Comcast DSL internet. i show that i am connected but i can not get online. i duplicated the MAC address i just dont know what else can be wrong. is there a...
    The first thing is that Comcast is Not a DSL connection it is Cable connection. Now first make sure that your computer will be able to go on line when connected directly to the modem. Connect your main computer directly to the comcast modem and check if that goes on line. If not then you will need to contact Comcast and get main computer on line. If it is online then reset your router for 30 seconds. release the reset and wait for 1 minute. Now connect the main computer to the router and comcast modem to the router. open the set up page and Clone the MAC address of the " Main " computer.
    power cycle the modem and the router. See if it works.
    Click here for more information about router and networking
    Apr 19, 2010 | Zonet ZSR1104WE Wireless Router
    Belkin 54g Router won't connect to internet.
    If you can access the configuration page of your belkin router you have to copy the MAC address of your computer to the router. The router has the capability to clone the MAC address. It's because if you have a cable internet connection the MAC address is registered in the server.
    Jan 06, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
    BelkinMIMO wireless router stopped connecting to internet
    I just installed a Belkin N1 (model F5D8635-4 v1000) to a Comcast Arris modem in SW Florida by resetting the IP on the router to 192.168.1.1 Comcast assigns 198.168.0.1 (but will accept 192.168.1.1 however not .2.1) and Belkin default is 192.168.2.1. Problem is easy enough to correct by following the instructions for changing the default router IP using a Firefox interface as documented in the user's manual. Note that when applying changes it takes about 30 seconds for changes to be effective.
    Sep 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    Surfboard Cablemodem not communicating with Belkin Wireless Routr
    If the modem is actually passing out DHCP, then you have to connect the modem to the router 4 port lan side and not the wan port. Give the router a static ip like 192.168.1.2 and you can talk to it and configure the wireless features.
    Feb 17, 2009 | Arris SURFboard SBG900 Wireless Router...
    Belkin G wireless Router
    Do you have an all-in-one router from Comcast? For example, do you have the cable (RF) line and your PC plugged into the Comcast router? If so, unplug your PC from the Comcast router and connect the Internet port of the Belkin to the ethernet port on the Comcast router. Then plug your PC into the LAN port on your Belkin.
    [PC] ---> [Belkin] ---> [Comcast] ---> Internet
    Once you have connected your boxes as displayed above, you will need to power everything off and bring up the boxes in the following order:
    Comcast (wait 60 seconds)
    Belkin (wait 60 seconds)
    PC
    If you cannot get out to the internet, momentarily press the reset button on the back of the Comcast box. Comcast routers are weird. A poweroff should reset the router but I have seen a few times where nothing works until the reset button is pressed (this is also recommended by Comcast).
    I hope this helps.
    Dave Grannas
    Jan 26, 2009 | Belkin (F5D7230-4) Router (587009)
    Router stoped working
    yes new roughter netgear is easy plug in play vs linksys new model u can try hard reset button on back if your router has one still dont afte rthat cheak dns server code if u need one they woulve told u his to at start maby cheak for latest firmware for it if any is out ok otherwise ya get upgrade be faster then belkin
    Oct 06, 2008 | Belkin (F5D5231-4) Router
    Belkin N1 Router connection drops when phone rings
    You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
    Nov 09, 2007 | Belkin (F5D8231-4) Wireless Router...
    Belkin (F5D7231UK4) Wireless Router Logo
    98 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
