Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety.
1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
how to replace copier drum Cleaning Blade - photo2.gif"/uploads/images/photo2.gif" alt="photo2.gif" class="h_mi" />
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the show to replace copier drum Cleaning Blade - photo3.gif and the sawteeth.)
5) Remove thehow to replace copier drum Cleaning Blade - photo4.gifblade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber withhow to replace copier drum Cleaning Blade - photo5.gif.
•When attaching the cleaning blade, press the cleaning how to replace copier drum Cleaning Blade - photo6.gifhe arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process framehow to replace copier drum Cleaning Blade - photo7.gif •Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and thow to replace copier drum Cleaning Blade - photo8.gifnductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the dhow to replace copier drum Cleaning Blade - photo9.gift its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib
with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade
may need to be re-positioned or lubricated with a small amount of toner.
