Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Moved refrigerator. Won't get cold now unless at 9.
I just moved a side-by-side GE refrigerator (9 years old). I tipped it to about a 45 degree angle to move it and blow out the dust (got three large bunnies!) I didn't hit the coils or tubes with the two wheeler. The fridge moved from the kitchen to the garage where the temp is about 10 degrees hotter.
Now the thing won't cool to below 45 unless I crank it up to the highest setting - 9 on this model.
Any good reasons this might have happened?
  • stevepotter Jul 01, 2008
    Forgot: the freezer works fine. Just the fridge needs to be at 9.
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 05, 2008
Slow to cool. bought used only got to 45 in frig. reset on 9 and in 24 hours stay at 38 to 40. But moved to 7 and it is at 45. GE tfh22 PR. Thanks for your input.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Moved 9 year old kenmore to friends house just replaced ice maker. lights come on but refrigerator is not getting cold water is running ok but is warm
Is the freezer getting cold?
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge side working but only cooling to 50 degrees
My 14 years old GE profile refrigerator keep cooling above 50 degrees and not going down to below 40 degrees. I did clean condenser coil and fans are running fine. I adjusted temperature control to maximum cold .Do you think it my be short of refrigerant?
Jun 17, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator is too cold (28 degrees)
this is likely one of the thermistors on the fresh food side has failed. They are usually located under a small cover inside the fridge. They should have a reading of 15.5k-16.5k ohms at 72 degrees. They are easy to check and replace. Here is a link that should help. You can also enter your model # for diagrams and illustrations of your specific model. http://appliancehelponline.com/sxsfreshthermistor.html
Jul 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not geting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Fridge was moved (not on it's side) and it not cooling properly.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
.,.vnkxgd
Dec 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator too warm on coldest setting
The refrigerator coos from the bleed over from the freezer, See if the fan in the freezer is working properly and the crossover duct/vet is not obstructed or close.. Ck to make sure the control in the fridge is working,
Nov 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerator will not stay cold
Bought a second hand fridge that was running well. We layed the fridge on it's side for moving and let it stand upright for at least 4 hours. The moving was only 45 minutes. The freezer is semi-cold but the main body of the fridge stays at aprox. 68 degrees. Any solutions.
Oct 31, 2007 | Refrigerators
Refrigerators Logo
239 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
