Question about Sony KP-61HS10 61" Rear Projection Television
Tv Problem TV picture and soung keeps going on and off, and red light blinking. Seminolebob@live.com
  • 5 more comments
  • spannman Aug 18, 2008
    The picture and sound go blank..red light continues to blink. Quite annoying..any help will be greatly appreciated.
  • raiderswatso Oct 20, 2008
    hello pleas help wen i turn my tv on the red power light flashes on and of and also i don't now how to get rid of the tv's split screen.
    thank you
  • elgaucho Nov 06, 2008
    Same exact problem, the image keeps going off and coming back on and the red light blinks.
  • Kurt Barton Nov 08, 2008
    KP-61HS10, standby/timer light blinks 5 times, picture flashes off then back on. Audio not interrupted.
  • Anonymous Jan 30, 2009
    MODEL KP-61HS10 LIGHT BLINKS 5 TIMES PICTURE GOES OFF, VOLUME STILL WORKS
  • klloyd66 Apr 21, 2009
    I am having the same problem with mine. The flashing light will blink 5 times and the screen goes blank, but there is still sound. I have the KP-61HS10. Is this an easy fix or expensive one??
  • raiderswatso May 11, 2010
    the red light just keeps on blinking and yea it is that model but also do u now how to get rid of the split screen.
  • Sony Master
  • 8,617 Answers
How many times does the light blink in between pauses? Also is your model the KP-61HS10 ? Please respond to this same post and I should be able to help you.
Posted on Jul 01, 2008
  • Deneice M Mar 26, 2012
    I have the same issue. It blinks 5 times. One option I read was to go to the Advanced Video Settings Menu however each time the TV blinks the menu disappears before I can even get a quick glance in. Another thing I read was that it could be the Video output. Would plugging my DVD player into a different output slot help? Would solving the problem be any easy and cheap do it yourself fix or would I need a repair shop? Any advice would be greatly appreciated!
    Deneice
  • Sonny Berry
    Sonny Berry Mar 29, 2012
    Check transistors Q510, Q516 and Q524 all located on the A board. Thats what usually causes the 5 blink error the video output transitor on either the Red, Blue or Green CRT drive boards could cause the issue but they are far less likely.
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
My sony kv-36fs13 picture is very red. I tried adjusting the hue without success. I am getting the little red light on the front of the tv blinking five times. Any ideas?
open the back cover of your TV (unplug the unit) using a soldering Iron,resolder all the components at the CRT socket .the small square board attached to the tail of picture tube That's it! good luck and please dont forget to rate I need it to keep going...
Mar 08, 2011 | Sony KV-36FS13 TV
I have a sony trinitron flat picture 19 inch tv. i live near ocean environment. so there's salt air and also humidity. many tv's have come and gone. my tv's red light blinks too. so i know there...
Your case is a pure case of component deterioration with added salty moisture build up which corrodes and makes circuit joints weak. the fault will only keep increasing according to the damage. here are some tips to help;
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
Sep 29, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
No picture, green light keeps blinking, hear fan go on then off, blinking light changes to red
Count the blinks between the pause, Let me know or call a sony service center if your a novice at tv repair
Apr 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Tv Problem
Sony TVs generate an error code. The front panel LED (red) will flash anywhere from one to eight times which can isolate the problem circuit. It is not always accurate.
If you have a test meter which can read DC voltages and resistance in ohms, you can locate the problem area. If you lack the expertice to do so, contact a sony authorized servicer. If you have the ability, start by checking fuses on the "G" board ( power supply board) and the "D" board or deflection board.
A major problem area in this TV is the convergence circuit. There are six fuses around the convergence output ICs on the "D" board.
If any are open, replaces the output ICs.
Feb 13, 2009 | Sony KP-61HS10 61" Rear Projection...
Tv turns on but no picture just a red blinking light stays on
Red light blinking means there's a problem in the TV....
What kind of tv is it?
Feb 10, 2009 | Televison & Video
Where can I find a Samsung repair center?
LG DLP PROJECTION TV (RU-44SZ63D) Tv light is off (with red light on). When I hit the power on button the red tv light starts blinking. Light continues to blink red then stops blinking and goes back to off (red light on).
Jul 12, 2008 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Sony KP-61HS10 61" Rear Projection Television Logo
193 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
