Question about Krups FBC5 1600 Watts Toaster Oven with Convection Cooking
Replacement Door Haven't received replacement door yet. Will wait until it comes and then get back to you. Thanks
    Genius:
  • 2,028 Answers
No problem, let me know.
Posted on Jul 01, 2008
It wont turn on model T0131SWD!!!!!!!
follow this charter troubleshooting and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#1#ixzz2gUR97IFo
Oct 01, 2013 | Black & Decker Toaster Ovens
Door Replacement
  1. To fix a cocked door, open the door and loosen the screws securing the inner panel. Hold the door at the top and twist it from side to side to seat it securely on its hinges.
  2. Partially tighten the door screws; do not overtighten screws on a porcelain door because the surface may chip.
  3. Test the seal by inserting a piece of paper between the seal and the top corners of the oven. The seal should tightly grip the paper.
  4. To replace cabinet-mounted springs, remove the storage drawer and the oven door. Unhook and replace the springs. Replace both springs even if only one is broken.
Hope that helps..........
Jul 01, 2008 | Krups FBC5 1600 Watts Toaster Oven with...
Toaster oven door will not close completely.
This problem is caused by screws being loose or dropping off a limiting bracket on the left side of the oven behind the left outer wall.  This bracket allows the front glass panel to remain OPEN, as required for broiling.
To correct this, first check to see that the two black screws facing forward, behind the left side of the front glass panel are tight.  If not, tighten firmly, but be careful not to overtighten.  If this fails to correct the problem, then follow this procedure.
Purchase 2- #4 x 1/2" SS Phillips Pan Head sheet metal screws at your favorite hardware store.  Cost About $1
  1. Unplug the oven and place on a flat work surface. Place a rubber mat or towel under the oven to prevent scratching.
  2. Remove 2- #4 x 1/4" black phillips flat head screws on the left side of the front glass panel which screw into the black side panel.  These are NOT the screws which hold the bracket, which face forward, but are adjacent to the bracket screws.  Be sure to indentify the proper location of all screws for replacement.
  3. Remove the 4- #4 x 3/8" SS phillips pan head screws at the bottom of the left side of the oven.  Pry the metal tab of the back panel slightly off the bottom of the black side panel.
  4. Remove the 3- #4 x 3/8" SS phillips pan head screws from the back panel which attaches to the left side black panel.
  5. Carefully pry the bottom of the left black side panel up from the bottom of the oven until it is parallel to the top of the oven.  It will seem hard to pry it upward as you are bending two SS tabs holding the black side panel to the SS top.  It will come up easily once you get it started.  When it is parallel to the top, slide the black side panel to the rear to remove it from the two SS tabs.
  6. You should now see the limiting bracket at the front of the oven's left side.  Remove the 2- black Phillips screws holding the bracket.
  7. Slip the limiting bracket from the oven.  Place on a wood block and with a chisel (or large common screw driver) and hammer, strike the screw holes on the bracket firmly once, so as to close the screw holes slightly.
  8. (OPTIONAL)  If available, using a rat tail file (or small flat file), at the crook of the spring lever, carefully increase the indent of the crook ever so slightly.  This will allow the front glass panel to stop more definitely at the open point.
  9. Remount the bracket using the 2- #4 x 1/2" SS Phillips Head sheet metal screws you bought. Tighten firmly, but do not overtighten.  Check the front glass panel movement. It should have a definite stop to allow the panel to stay open approximately 1/2" for broiling and should close fully, easily.
  10. Slide the left black side panel on to the SS tabs.
  11. Pry the left side black panel down until it meet the bottom plate.
  12. Replace the bottom screws.
  13. Replace the 2- #4 x 1/4" black Phillips flat head screws at the left side of the front of the front glass panel which screw into the black side panel.
  14. Replace the back panel screws.
Feb 23, 2009 | Cuisinart TOB-50 Toaster Oven with...
Farberware convection broil oven modle T-4850
I have the same problem. www.repairshack.com has replacement doors but they are out of stock. You may want to check with them to see when it comes back in. Specifically http://www.repairshack.com/detail.aspx?ID=705 or call
1-888-464-0797.
Jul 30, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Broken Door
This is a special heat treated glass and you will likely have to buy the door from them
http://www.shoposter.com/customer_care.asp
Jan 30, 2008 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Oster Toaster Oven 6232 replacement parts?
Write to Oster and they might give you a new one depending on how old it is
Spring in door
I have the same problem. The end broke off. I heated the end with a torch and bent a new loop (cooled it in cold water). I hope it will work for a while. I could find a replacement on the internet. To get to the spring, just remove the left side panel (3 screws)
Jan 06, 2008 | DeLonghi EO1238 Toaster Oven with...
Not Heating
I just opened one with the same problem. The bi-metal switch / thermostat was completely burned out and melted into a small lump of metal. Unless you can get a replacement for that it might be the cheapest to go to a store and buy one new for under $80.
Aug 24, 2007 | Hamilton Beach 31197 120 Watts Toaster...
Krups FBC5 1600 Watts Toaster Oven with Convection Cooking Logo
120 people viewed this question
Top Krups Toaster Ovens Experts
warcraft demonhunter
Level 1 Expert
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
