Question about Apple iPod touch
Ipod touch whenever i turn my ipod touch on the screen just flashed white, gray and black is it broken or what????
    Problem Solver:
  • 12 Answers
Hold both the sleep and home buttons untill your ipod shuts off, keep holding untill your ipod starts up and let go of the sleep button but continue to hold the home button. you can let go when a screen showing you to connect to itunes appears, you can now continue to restore your ipod in recovery mode! hope this helps
Posted on Jul 20, 2008
    Problem Solver:
Maybe you should reset your ipod by pressing both the menu button and the power button. If this doesn't work I'm really sorry.
Posted on Jul 01, 2008
How do I turn on and off private browser on my I pad
Turn off Private Browsing. On an iPhone, iPad, or iPod touch, open Safari, then tap . Tap Private, then tap Done. While Private Browsing is on, Safari appears black or dark instead of white or gray.2 Aug 2016
Turn Private Browsing on or off on your iPhone, iPad, or iPod touch
https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=How+do+I+turn+on+and+off+private+browser+on+my+I+pad
Dec 20, 2016 | Computers & Internet
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
Ipod has locked up with a blank grey screen
how old is the battery it might need to be replaced
Charge the iPod
If your iPod touch suddenly goes blank while you are using it, the culprit could be a low battery.
Prior to the screen blanking you may see a low battery indicator.
If the screen is completely blank, try plugging the iPod touch into a power source and letting it fully charge before attempting to use it again.
Restart the iPod
If you've got a white or gray screen, try to restart the iPod.
Sometimes a simple restart will solve the problem that initially caused the white or gray screen, and the iPod will work as expected once you have turned it off and on.
Reset the iPod
Resetting the iPod Touch goes a step further than just restarting, and it is a good option if you've charged the iPod and restarted and you're still seeing a blank, white or gray screen. Press on the "Sleep" and "Home" buttons simultaneously for at least ten seconds before releasing the buttons. At this point, you should see the logo or a battery icon, if the phone needs to be charged.
Restore the iPod
If nothing else has worked to remedy the malfunctioning screen on your iPod touch, try restoring the device. Connect it to your computer and open iTunes, then click on "Restore" which is found under "Summary." Be sure to back up your files when prompted, because the restore will change all of the settings on your device back to the factory default.
If even this does not work, you almost certainly have a hardware issue, and will have to take the device to an Apple store for examination and possible replacement.
hope this helps
Oct 06, 2012 | Apple iPod touch 4th Generation MP3 Player
Ipod touch will not turn on
Thank for contacting Fixya, I will be glad to assist you.
What you can do, in order to resolve this issue, is start by resetting your iPod Touch
(Note: this does not remove any settings, data or media you have installed in your device)
• To perform a hard reset, press and hold your Sleep and Home Menu buttons for approximately 10 seconds.
• Once your screen goes black, release both keys. (If you see a white Apple logo before you release the keys you have held the keys to long and will need to start the reset process once again)
• The next screens you should see after the black screen, is the Apple logo screen followed by the main screen.
Let me know if this helps.
Regards,
-The MacTechTrainer
Nov 06, 2011 | Apple iPod touch
After my itouch charged it went completely blank. It had a white screen, flashed white and black --- now only white, empty screen.
plug in to computer and the hold home button and power button down for 15 seconds then restore
Feb 17, 2010 | Apple iPod touch
Dropped itouch now half of screen is gray everything else works fine just can't see half the screen
It's most likely a broken LCD. You can use a ipod repair guide that will show you how to replace the screen step by step, or you can go to the ipod repair nyc.
Jul 20, 2009 | Apple iPod touch
Ipod Touch 8GB Screen Problem
the white apple is the start up but the white flahes is weird
Apr 04, 2009 | Apple iPod touch
Ipod touch 2 gb screen went white
that happens sometimes. whenever it happens, hold the power and home button until it turns off. then turn it back on
Mar 25, 2009 | Apple iPod touch
Itouch screen is white then, when restored goes black.
make sure u hold down home and sleep buttom for more than 11 seconds. After the allple logo shows up, press the home button...i had similiar problems as some of u, and this unfroze/ fixed my issue. Hopefully, it will work for u
Feb 22, 2009 | Apple iPod touch
Apple iPod touch Logo
138 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
