Question about HP Photosmart C6180 All-In-One InkJet Printer
Photosmart 2575 printer is offline - won't print
Am not computer saavy, have two computers and the HP into a "switcher" that then is hooked to single DSL line. Older computer has XP and the new one has Vista. New computer has two printers listed on printer section of Hardware and Sound on Control Panel - 1. Microsoft XPS Document Writer, printer status Ready, 2. HP Photosmart 2575 (set as default), printer status Offline. Printer works through old computer, will not print through new one - job spooled on queque. What the heck is the XPS Document Writer? Afraid to delete it not knowing what it is and how do I get the Photosmart Ready, i.e. change status from Offline. Please make explaination simple. Thank you for any suggestions. I am having the same problem, but on a HP Photosmart 6180. I right clicked to change the status to work online, but it just added offline again. Help.
  • 405 Answers
Good Day,
One thing you can try instead of deleting the doucment writer is to change the default printer. You can do this by right-clicking on the HP printer icon and selecting "set as default" from the drop down box. Also try turning the printer off and back on aswell as restaring the computer if you have'nt already. Did that printer ever work from that computer? How is it wired, by "switcher" do you mean a shared printer through you network(was printer sharing configured properly), or an A-B printer switch. Please clarify
Hope this helps for now
Posted on Jul 01, 2008
Trying to access DSL with HP modem
If you mean you're trying to use DSL service with the modem that came built into an HP computer, you can't. That modem is for dial-up Internet service only, or if you want to use your computer as a fax machine along with a scanner or all-in-one printer.
To connect to DSL, you'll need a DSL modem. If you're just getting service, your service provider should have supplied one. (Actually, I think you have the option now of ordering DSL service and not getting a modem if you already have one. Maybe you did this.) The DSL modem has a telephone-type jack to connect to the phone line (same as on the HP modem), but the connection to your computer is through a different, larger, jack usually labeled "Ethernet" or "Computer". If you don't have a modem, you can easily find them for sale. You can buy new ones at retailers who sell computers, and many used ones are available on eBay or on your local Craig's list.
Another possibility is that you already have a DSL modem and are asking how to connect an addtional computer. If this is so, you don't connect the new computer to the DSL phone line. Instead, you need to share the network connection coming from the modem. This is done using a router, which allows several computers to use the same connection either through a cable or wirelessly. The DSL modems typically supplied now have the router built in, with 4 connections for wired computers and wireless capability as well. If your modem is an older one intended for a single connection only, it will have just one network connection. If this is the case for you, you'll need to supply your own router.
Apr 26, 2011 | Computers & Internet
I received a new 2wire 2701HG-B modem router for AT&T DSL (replacing an older 2wire that burned out) and was able to hook up laptops right away no problem, but desktop doesnt recognize new modem how do...
are you on windows XP, Vista, MAC ???
you start out by seeing if you can ping the 2wire. The ip address you ping from a command prompt is the 2wire's gateway,
(you can get to the command prompt by clicking start, then click run, and type cmd and click ok on windows XP)
(on vista, you just click start and type cmd right above it where it says start search and hit enter on your keyboard)
(MAC's have a ping utility located by clicking on the harddrive, applications, network, network utility, and then the ping tab)
a little black window pops open, thats your command prompt
type ping and hit enter on your keyboard
if you dont get replies, then your computer doesn't see the 2wire.
call tech support at 877-722-3755 24/7 for further support if required. We can make sure you nic is config properly, working properly, your not being blocked by a firewall, etc.
Sep 13, 2009 | 2wire 2700HG-B Router (2700HGB)
I can't fax....HELP
Yes. But your fax machine must be hooked up with a standard phone line to the jack on the wall, or to a computer linked to a standard phone line. You can't simply hook the computer up to a dsl ethernet cable and hook the usb cable up to the printer and expect fax services to work.
Hp has an excellent support site for use with it's printers, available by clicking here Please take a look at this fax set up link by clicking here to make sure the fax is set up properly,and if it is and you're still having difficulty, take a look at the main site solutions section to troubleshoot your particular machine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 06, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Trying to hook verizon UM150 card to verizon wireless DSL Gateway
the UM150 wireless card goes into the computer.
however, the DSL need to be wired to your computer for initial configuration.
if you just hook up the DSL as verizon say, then you will have a open wireless network, anybody can get access to your network.
Feb 03, 2009 | Verizon Communications Ethernet/Wireless-G...
Machine does not receive faxes
It the funky line DSL?
Fax machines are designed to be on a dedicated ANALOG phone line. Sorry
Oct 16, 2008 | HP 1040 Plain Paper Inkjet Fax
In Vista make sure you are logged in as a administrator whenever you make any changes.
And if not to bring the printer online you will have to right click on the printer icon and right click on Run as administrator> and then try bringing the printer online and checdk if it works.
And you can delete the Microsoft XPS Document writer it is a default printer icon installed if in case you did not have a printer installed you can store them to print later.
Now that you already have a printer you can delete the Microsoft XPS Document writer.
Good Luck
Oct 02, 2008 | HP Photosmart C7180 All-In-One InkJet...
DSL (2wire modem) and LAN conflict
You can actually try accessing the interface of your gateway and put it on DMZ mode. That way it will open the ports on your gateway to ensure passage of all data from your gateway to all your computers even when the dsl is on. But make sure tat you have security software installed on all your computer workstations bec. putting your 2WIRE gateway on DMZ mode will expose your connection.
Aug 15, 2008 | 2wire 2700HG-B Router (2700HGB)
Hey jonboy - You do not want to delete it. It is automatically installed with Vista. In simple terms, you know when you go to print something and it asks you questions like print all pages, print page 1, etc? Well XPS basically is there for so when you go to print, you have the option of printing to a file instead of paper. You've always had that option ( whether or not you knew it) but this is just a new way of doing it and that's why it's listed under printers. It's sort of like a virtual printer. I'll say no more about that and just hope you understood what I said. As far as the other printer, it's already selected as default, go back in where you found the printer status, right click on your Photosmart and click on use online. That should do the trick.
I hope you understood this stuff. If this solves your problem PLEASE rate this as fixed. If you still have a problem, DON'T RATE it yet just add a comment and I'll be happy to assist you further. Thanks.
May 09, 2008 | HP Photosmart 2575 All-In-One InkJet...
Have an Acer Aspire PC computer - trying to hook up a Lynksys nr041 router so can hook up another HP Notebook computer...not for sure how to do this and be able to use internet on both computers. Thanks...
Ok if you have DSL this router will NOT connect via PPPoE so no user name or passwords for dsl. But if you have a cable modem just plug the network cord from your cable modem into the WAN port on router... then plug the computers into the 1-4 ports on the router.. you might need to reset your Cable/Dsl modem after everythings hooked up.
May 02, 2008 | Linksys (NR041) Router
2WIRE Single Port DSL Line Filter
i think when you purchased the 2wire modem it usually comes along with 3 sets of single port dsl line filters, try out those other filters see which one works. if the local network light doesn't come on, (are you using 2wire 1000 series?), check the network adapters in your computer, this usually happens when you are using lower versions of OS. try the power outlet in the kitchen / bathroom, if power light doesn't come on, push the reset button for 30 secs. if power light is still off or red, then you may need to replace the modem (check if it's still under warranty, if not you will need to buy a new one.) also you should be using the same power adapter that came with the modem, check the specs. sometimes if the modem is more or less than 3 years old, they could get defective especially if it's often affected by sudden power surges.
Jan 29, 2008 | 2wire Single Port DSL Line Filter (21869)
HP Photosmart C6180 All-In-One InkJet Printer Logo
242 people viewed this question
Ben Johnson
