Question about Samsung HCM653W 65" Rear Projection Television
Samsung HCM653W 65 in rear projection tv
Mr. Techman,
Last time I asked your advise for my above tv problems. You told me to check the fuses on power supply board. All fuses are ok. I already replaced Assy PCB,SUB,PCL54r,54a, but no answer for the problems. This time I am sending the TV Image for more details. Please advise me.Thanks for last tips.
Thanks again.
Nicky
  • DollarTech Aug 22, 2008
    Do I try buying a power supply board and try, or wait for solutions from you experts.
    Thanks.
    Is convergence board is part of SAMSUNG main board (p/n: AA94-07625H) ?
    Thanks for your tips.
  • 2,336 Answers
Could you provide us with the exact part number you've replaced?
Posted on Aug 22, 2008
  • Jaime Hernandez Aug 22, 2008
    Did you replace the board found in this link?
    Did you see the picture from the link I've sent you?
    Does the main board you bought is the same or similar to it?
  • Samsung Master
  • 19,396 Answers
This has nothing to do with fuses
  • Ginko
    Ginko Aug 22, 2008
    The problem is either color wheel, or convergence settings.
    Master:
  • 521 Answers
Its the convergence board/bulb problem for sure.check that and replace it.every thing will be fine.thanks.
  • 1 more comment
  • tech expert12 Aug 22, 2008
    if the problem of fuses or powersupply board no power will come.but the power is coming properly.
    just convergence board/bulb problem.
  • tech expert12 Aug 25, 2008
    yes convergence bulb/board is the part of main board.thanks.please rate the solution sir.
Mitsubishi WS-65313 65 in. TV will no longer power up.
You should call a good TV Tech. This problem cannot be solved by a consumer. The one thing you might try is to unplug it from the wall for a few minutes and then try it again.
Aug 03, 2009 | Mitsubishi WS-65313 65" Rear Projection...
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
HCM653W color convergence off
Ck low ohm resistors 3.9 omh and pico fuses they look like resistors but they are green or yellow 5amps, 6amps,sometimes after replacing STKs there is bad resistors or open pico fuses.
Dec 22, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W Convergence problem
CK low ohm resistors and pico fuses some are green,some are yellow .they will be around ics some may be under heat sinks that hold STKs.
Nov 29, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W
Convergence board will have 2 big black ics on it STK392-110s or 150s Use number on STK s in your set.To get parts call 1-800-223-3205 Electronix Parts.
Aug 25, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W 65 in. Television
Dear,
I do not know, what the problem you have in your tv M/N:HCM653W. I have the same Model samsung tv. I have image ghosting problems. As per tech I replaced the Pcb,sub.samsung part AA95-01846D, Which did not fix the problem. I still have it for sale. The power supply pcb is no longer availabe as per"Partsstore.com. I have no idea where you can find the power supply board. If you find it,please let me know.
Thanks.
DollarTech
Jun 18, 2008 | Samsung HCM653W 65" Rear Projection...
RGB COLOR PROBLEM.
You will need to check the plus and the minus convergence voltages in the main power supply. There are a couple of circuit protector fuses that go bad. Do not replace these untill you replace the convergence IC's or you will cause more problems in the main power supply. Good Luck
Apr 22, 2008 | Samsung HCM653W 65" Rear Projection...
Mitsubishi WS-65869 65 in. Power Light
They are little green soldered in fuses located on the center board (the one with the STK's on it) toward the rear of the set near the large transformer.
Aug 24, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Convergence problem
This convergence boar should be available from ptscorp.com. Go to the website, look up the telephone number, and call them and see what a new convergence amp board cost. Good Luck
Jun 15, 2007 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W 65" Rear Projection Television Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
