Question about Gateway Computers & Internet
Everything on the monitor screen is sideways - Gateway Computers & Internet
Hi, try hitting ctrl alt and up arrow at same time.
Posted on Mar 25, 2009
Computer screen is sideways
Sideways Screen: try this
Try pressing Ctrl + Alt + UP Arrow Key, or try Ctrl + Alt + and a different Arrow Key.
If that does not work: Right-click on empty Desktop > Graphics Options > Rotation.
Jul 07, 2014 | Computers & Internet
Icons and text exhibit a right-handed black and white dithering or noisy shading effect. This gets increasingly bad as windows are opened and closed. It almost looks like a RFI/EMI radiation problem but...
If the monitor displays a similar effect on the monitor's own display, the colour ajustment or no signal display then the answer is most likely yes. A good tech guy may be able to fix the problem but it's going to cost almost the price of a smaller screen, similar to what you have, anyway. My suggestion is to just grab yourself a new monitor.
May 07, 2011 | Balance CM2019 19" LCD Monitor
The screen is turned sideways
It sounds like you accidentally press the key combination to rotate the screen. This is a feature on some video cards to allow portrait display with the right monitor. Your monitor does not rotate so the picture is sideways. To correct this problem simply click CTRL + ALT + Up Arrow and your screen should return to the correct orientation.
I hope this helps, if so please rate our solution.
BuddyMc
Dec 22, 2010 | Dell E173FP 17" LCD Monitor
The creen on my laptop is rotated sideways how do I fix it everything on my screen is sideways and i need it to be up and down so i can read my screen right side up on my laptop computer
Based on your brief description, I think your problem is correctable in the control panel under monitor settings. Depending on your operating system (XP, Vista, Windows 7) you will need to find the monitor settings and look for the advanced section for the Nvidia Video Card. In there you should find a setting to flip the monitor view between Portrait and Landscape. The settings may be named differently, but there will likely be a graphic representation to show you the different settings available.
Nov 29, 2010 | Dell Inspiron 1525 Laptop
I have Windows 7 on a new computer. The view is sideways now.
press and hold ctrl + alt key + up arrow key. this will put your computer back to lanscape.
May 06, 2010 | Dell Inspiron 530 Desktop Computer
PICTURE ON MONITOR SCREEN IS SIDEWAYS
Your screen is set to sideways. These the common features for all video cards. You can set it back to default, just go to video control panel of your video card and find Display Rotation.
Nov 03, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Icons and everything displayed sideways
If you're referring to the taskbar that's usually on the bottom of the desktop, click on the taskbar and drag it to the bottom. Then right click on the taskbar and check "Lock the taskbar". This should solve your problem. All the best.
Greg
Jun 23, 2009 | NEC MultiSync 77F 17 in.CRT Conventional...
Everything is displayed sideways on my monitor. how can I fix that ?
I suppose you have Nvidia Card Installed if yes then Right Click Your Desktop and select Nvidia select Standard Settings and go to Display + Rotate Display and set No Rotation . Thats it!
May 10, 2009 | Dell E173FP 17" LCD Monitor
Monitor screen displays sideways
if the screen is rotated then press
ctrl + alt + up arrow
your screen will be placed correctly
this is happened because sometime you might have pressed by mistake ctrl + alt + some arrow key .....
the hot key will be enabled defaultly so your screen got rotated
Jul 05, 2008 | Gateway FPD1950
15" Dell monitor
You have your video card set to rotate the screen after Windows loads.
Go into your display properties using it's control panel and look for the rotate section. Set it back to 0 degrees. Make sure you click apply and then OK, not just OK.
Apr 18, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Computers & Internet Logo
239 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
