Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Turned off and now won't turn back on
I turned the tv off and right away tried to turn it back on but nothing would happen.
  • 5 more comments
  • keri_n_keith Jul 10, 2008
    I have this same model tv, and it worked last night and it has not worked all day, we have unplugged and tried a different outlet and it still will not turn on. The "red" power light will not even turn on when we attempt to turn it on.
  • blumaria Sep 12, 2008
    I turned off my TV before going to work yesterday morning and when I came home, I tried to turn it on and can't get it to turn on. I have tried all the same things that cindyp60's tried. Still no luck. Any suggestions?
  • orion123 Nov 24, 2008
    The power will not turn on. It was being used one day, and then the next morning it would not turn on. I have checked the power plug and all seems OK.
  • unchel Nov 28, 2008
    I turned off my tv and tried o turn back on right away, now it tries to turn on but shuts off without ever displaying a picture.
  • klenke3 Jan 08, 2009
    I have the same problem, does anyone have a soultion?
  • Anonymous Jan 17, 2009
    I don't know if this will solve the problem, but I had the same and unplugged it for 10 seconds then plugged it back in.  That fixed the problem.
  • nikination Feb 18, 2009
    We turned ours off and now it won't turn on. We have tried unplugging it, leaving it unplugged, then plugging back in and still nothing. The red power indicator light does not come on at all.
  • Philips Master
  • 8,617 Answers
Can you verify that 55PW9363 is the actual model number of your set? Also does the power indicator light up when you press power? Please respond to this same post
Posted on Jul 01, 2008
My TV won't turn on. I have a 42" Sanyo LCD TV. We
You have a back light issue. Sometimes it's cheaper to get another one. Tcon board failure most likely. If you can find a rv repair or electronics repair they might do the work but as you got 5 years from it. Most TV sets fail in less time than that.
Jul 20, 2017 | Televison & Video
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
Have vizio vw46lfhdtv10a won't turn on
The other expert here is right--main is not being turned on and either main board or power supply could be bad.
Apr 26, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
Had electrical storm last night. Tv shows the Westinghouse symbol, nothing else. This is when it is turned off. When you turn it on (from the tv, remote won't work at all), symbol disappears for 30...
If your TV has a reset switch on the back, use it. If not, Unplug the TV, hold the power button down for 30 seconds, let it go and remain unplugged for another 5 minutes or so.
Plug it back in, and see what happens. Try changing the inputs/channels/etc to see what happens. If you're still having this issue, Take your TV in for repair.
- Sidenote, a $25 power bar with built in protection curcuits are the easiest way to protect your equipment from this kind of thing, and quite a bit cheaper than forking over $300 for a new TV everytime there's thinder and lighting.
May 11, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
No standy lights illuminating..happened before thought it was bulb, replaced it, still nothing. put it away for about a week, plugged it inand it worked, has been working for 3 months and today when the...
Sounds like a power supply issue to me. Did you check the 1.5A fuse and see if its still intact? Check it with a multimeter and measure the resistance. If it reads a very high value then its probably blown. The fuse is located on the power board(the board where your power cord plugs into the tv). Also look for any visible damage like a swollen/cracked or leaky capacitors. The top of the capacitors should be flat, if its swollen or cracked, you will know its bad.
Let me know your observations,
Sai.
Jan 12, 2010 | Samsung HLT6176S Television
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
TV shuts itself off
Mine does the same thing , too. I turn it on and off repeatedly , but nothing happens.I unplug it to see if it resets and nothing still .
Aug 02, 2008 | Mitsubishi WS-65908 TV
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
