Question about Samsung HL-P5063W 50" Rear Projection HDTV
Loud humming noise with lamp failure
I have read a lot of issues that linked back to the lamp, and our problem was the same, 3 blinking light on front power button. However, we additionally have a loud humming noise that began when the tv first shut down with the lamp issue. I have replaced the lamp, but the "Humming" remains. It is not a loud squeal, as decribed as a symptom for the color wheel, so i figure it is probably a fan? if so, where can i get a replacement?
  • 3 more comments
  • sellis1053 Jul 28, 2008
    I'm not getting any lamp warnings, but I started getting the humming sound a couple of days ago. After a few minutes, it goes away and so far the TV still works fine.
  • jffwhitmire Sep 06, 2008
    MY T.V. HAS A LOUD HUMMING NOISE BULB HAS BEEN REPLACED , T.V. HUMS THAN SHUTS OFF, LIGHTS BLINK ITS DRIVING ME CRAZY.
  • mattslap55 Sep 28, 2008
    screen is black ,three lights are blinking , humming noise coming from tv
  • lanholmes Oct 05, 2008
    Loud humming Noise near lamp
  • gb30 Oct 25, 2008
    Replaced the bulb as directed in the manual when all three lights blink on the power button.  Had humming noise before and now after bulb replacement and now humming louder and TV intermittently shutting down.
    Champion:
  • 217 Answers
It's the color wheel
Posted on Jul 20, 2008
About a week ago I replaced the lamp in my samsung hls24266 with no incident. Now when I turn the tv on, I hear a very loud humming noise. I tried disconnecting the coaxial cable but it does not go away....
I can't explain the timing of your problem and why it showed up after lamp replacement, but Samsung color wheel failures are usually associated with a rather loud hum. I would removed the back, jumper the lamp door switch and try to determine exactly where the hum is originating from. I think you'll find the color wheel is the culprit.
Bill W
integrityhomeworx.com
Mar 08, 2011 | Samsung HLS4266 TV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have the same problem with the HLR4667W model.
The noise could be from the try joint on the main Board please try resoldering them all.
Main filters are common to be targeted.
Thks..
Jul 22, 2009 | Samsung DLP HL-P5663W 56" TV
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV keeps shutting down
Sounds like it may be a bad ballast
Mar 24, 2007 | LG RU-52SZ51D 52" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
490 people viewed this question
Jerry Greenberg
Jerry Greenberg
