Question about Maytag PYE2300AY Electric Dryer
Indesit IS 60 VS
Dear sir, i've opened the lid to the tuble and noted the snapped drive belt. For a change, i've decided to attempt fixing it myself. Not being mechanically minded, any chance you can describe what is needed to be done. Many thanks
  • 979 Answers
You may want to get some assistance here. Purchase a belt from an appliance store and your help put it on. It is not hard and should not take more than 30 minutes. Take the old belt with you and the model number so it can be matched up.
Posted on Jan 14, 2009
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
How do I fix belt on my hotpoint TVM570p dryer
To do the belt. + as long as your patience lasts...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic cap on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel. To pop the belt off, turn the wheel forcing the belt to the edge of the wheel. It will eventually come off.
6. to replace belt - see motor shaft at bottom of unit. Dangle belt round shaft of motor and gently pull so it does not come off.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
Oct 14, 2012 | Dryers
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
The pump keeps trying to prime. There is no air in the lines. all the valves are open. filter basket is clean. we've tried hitting the reset button, changing the prime time from 1min. to 5 min....
Most of the time you are sawing air from thpumo lid. Hav you lubricated the o-ring in the lid? If that doesn't work, keep working your way forward and lubricate the 3 way valves as well.
Jul 28, 2011 | Pentair IntelliFlo VS-3050 & VS+SVRS...
LOUD NOICE AND JUMPING
IT seems that the wash drum is hitting on the exterior body possibly the shock absorbers have flattened out. Also the balancing liquid in the top inner portion of the wash drum has leaked out u will have to check the two
Oct 08, 2009 | Washing Machines
Indesit washer not spinning
I had exactly the same problem. All seemed ok, except no spin. I followed Shaun's advice and replaced the module board. Cost of about f£23 from ebay, but similar price on espares.co.uk. Fixed it. Thank you.
Aug 04, 2009 | Indesit W 123 Front Load Washer
Final Belt Drive on HARLEY DAVIDSON
Belts = quite, durable, less cost to replace.
Chain = noisy, last longer, messy oil spots on floor, good ones cost $400.00 or more, have to keep adjusted, hard to break. Im a chain man myself.
Jul 03, 2009 | 1993 Harley Davidson FLSTF Fat boy
Kenmore 60 series will not drain
Well if this is a belt driven model then your solenoid coil is bad.
This model 's motor only revolves in one direction. To spin it has to shift gears. It does this by means of a solenoid mounted on the transmission called a wigwag. Note: if the lid switch is bad no power can go to the wigwag and shift it. If this is a direct drive model(no belt) then it has to be a bad lid switch.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Display lost brightness
forthe cost of the unit vs. the cost of having it serviced , ive decided to work on it myself. I have it narrowed down to the flourescent backlight or the backlight power curcuit.
Sep 16, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Maytag PYE2300AY Electric Dryer Logo
97 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
