I have a 42" magnavox plasma tv. Its about 2 years old and out of warrenty. The scrren is black I cant get the menu to appear or anything else on display. I can still hear sound through it though. What do u think.
Try a hard restart, which simply means unplugging the power cord of the TV, and replugging it after 4 hours have passed. This technique reprograms the electronics, to a certain extent. If the picture does not return, then you might need the expertise of a repairman.
In most cases the lower Y-Buffer board causes this issue. Unless you know how to work on a TV it is suggested that you have a technician look at the TV and repair it for you.
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
Look over your policy carefully. Magnavox does not hold there own paper for extended warranties. I would start with where did you purchase it, and who sold you the warranty. Magnavox did use a company called N.E.W. I think you have a third party involved.
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it. Good Luck.
Already tried that :(
