Did the new transistors shorted out? You maut make sure to checkt the gray tuning caps in the inverter output sections, if they are bad, the inverter will run at the wrong frquency and burns uo the transistors. You also need to look real close at the solder joints in the inverter sections, especially around the inverter transformers. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
12vdc is OK?
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
You may be better off getting the replacement board:
Replacement board: http://www.lcdrepair.us
Hopefully the lamp assemblies are OK.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Service manuals:
http://elektrotanya.com/?q=showresult&am...
Basic LCD monitor and LCD TV troubleshooting guide:
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Please post back what you find.
