Question about LG VX8300 Cellular Phone
Car kit mode
My phone is still in car kit mode and i did all the things the web site has said to do what should i do now
  • 3 Answers
Ok take a paper clip, and lightly graze it inside the chargerport of ur phone, slowlymove it left and right, lightly rub it against the top half of the little piece inside the charger port, look at yr creen andwait for car kit to turn off. if ur phone turns off, dw. turn it backon adn dont rub the area u were rubbing wen it turned off.
once car kit turns off, it most likely will turn back on, repeat thisstep. eventually,it will go away forever.
it took about a day for the car kit to stay away completely for me.
trust me, i've been were u are. i tried everything and it never worked. then wen all hoped seem lost, at 11:30 at night, i found this and it worked beautiful.
also, u dont need to use a paper clip, anything metal will work. but paper clips the best because of there size.=]
Posted on Jul 03, 2008
Lg vx8300 verizon says car kit display have no
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. and thats why you're not getting any sound. There is no specific setting to turn on or off 'car kit' mode you can use a paper clip or something and mess with the port a little bit to see if 'car kit' goes away or replace phone
Jun 23, 2010 | LG VX8300 Cellular Phone
Phone says
Car kit mode means one of two things, first it could have a piece of lint or paper stuck in the charge port making it think there is a car kit plugged in, or second it could be that some moisture got into the port and its giving a indication that something is plugged in. There is no specific setting to turn on or off 'car kit' mode
Mar 25, 2010 | LG VX8300 Cellular Phone
I am unable to connect to a bluetooth car kit with my samsung omni hd i8910 phone. Have spent hours reviewing settings on my handset and reviewing phone user guide. I have also checked handset is...
there's 2 things you need to do to get these 2 devices to communicate. One is to make the bluetooth kit "findable" (for lack of a better term). and also have your phone search for the searchable device.
I'm not sure what your phone car kit is.... but check the instructions on how to put it into search mode. (I know that with a bluetooth headset, you hold the on button in and the indicator will change to a different color indicating search mode.
once you figure this part of the equation out, then access the phone menu for blue tooth and search for bluetooth findable equipment and it should list your car kit on the phone screen.
After that it is just a matter of entering a typical 0000 id code if needed and it should be paired with your carkit.
hope this helps...
Jan 27, 2010 | Cell Phones
Car kit mode
Car kit mode is usually caused by debris in the phone's cable connector (at the bottom of the phone). The debris causes two or more contacts to be electrically connected to each other, causing the phone to think it's connected to a car kit. Remove the battery from the phone and clean the cable connector contacts with some rubbing alcohol and the corner of a towel. Also, try using an opened paperclip to scrape the contacts in the connector, this will remove any corrosion that may have built up.
Also this can happen due to shortening of the 2 power pins at the bottom. Try using an alluminium piece cone shaped and toggle the pins. They will come out. Car Kit mode comes sometimes due to moisture in the power pins, shortening it.
Sep 18, 2009 | LG VX3400 Cellular Phone
Stripped bolts on dakota
Go to this web site these Helicoil thread repair kits will work for your application, these Helicoil kits are the only way to repair threads that really work, These kits are available from premium auto parts stores like NAPA and CAR QUEST
http://www.cartools.com/Helicoil_Thread_Repair.htm Hope this helps, you can call if you like to clarify what you need further, Phone 925-577-7157, ask for Dennis
Jul 29, 2008 | 1998 Dodge Dakota
My phone is in "car Kit" mode
OKAY THERE IS WHAT YOU DO:
1.GET A PIN OR NEEDLE POINT. 2.LOOK AT THE CHARGER PORT 3YOU WILL SEE THE COILS OR THE PRONGS THAT YOUR CHARGER CONNECTS TOO 4 NEXT TO THE COILS, EITHER ON LEFT SIDE OR RIGHT SIDE THERE IS A SMALL BUTTON. LIKE A CIRCLE LOOKING THING. IF YOU CAN NOT SEE IT NO BIG DEAL 5. STICK YOUR PIN INSIDE PUSH THE LITTLE CIRCLE. IF YOU DON SEE THE CIRCLE PUSH IT ON BOTH SIDE 6. YOUR DONE.
Jun 30, 2008 | LG KE800 Smartphone
Car kit mode
Feb 17, 2008 | LG VX8300 Cellular Phone
Lg cell phone vx3450
This is an old post but in case anybody searches and finds it...The infamous "car kit" mode on LG phones is a problem I had. Your service provider will claim the phone got wet (they will look at indicators in the battery compartment and on the battery itself that turn blue in the presence of moisture. Trouble is, they will eventually turn blue just from humidity even if the phone wasn't given a bath). Search the web; there are one or two forum threads with many suggested solutions (such as resetting error codes in the service menu, scrubbing out the battery connector with a toothbrush, plugging/unplugging the actual car kit connector, etc.). None of these suggestions gave a permanent fix (YMMV) for me and I eventually bought a new phone.
Dec 10, 2007 | LG VX3450 Cellular Phone
Car kit mode activated
I found this on another site, it worked like a charm... roll a VERY THIN piece of aluminum foil, and slide it (almost jiggle it) in the POWER SLOT. I tried it and it worked . Apparently saliva, water or anything liquid will make the connection to activate the phone into the 'car kit mode', so the aluminum foil acts as a conductor and switches your phone out of car kit mode...
Peace
Nov 26, 2007 | Cell Phones
Operation
To edit the settings for the headset, car kit, or another audio accessory, open Enhancement settings > Headset. Scroll to the following setting and press OK to edit. * Default profile - Scroll to the sound profile that you generally wat to use with the headset and press OK. Hope this works for you.
Aug 11, 2006 | LG VX4600 Cell Phone Over-the-ear...
LG VX8300 Cellular Phone Logo
175 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
