Question about Nintendo 64 Console
Nintendo 64 im trying to hook my nintendo 64 up to a new tv. what do i do?
  • bonebayhon Jul 01, 2008
    whats an a/v converter
  • bonebayhon Jul 07, 2008
    thank you dorothy, it worked bonnie
    Novelist:
    Champion:
  • 216 Answers
Greetings bonebayhon,
Depends on what type of connections your television currently has. Most likely you will want to use an A/V selector to utilize the connections on your television. The best type of connection a Nintendo 64 has is S-video.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jul 01, 2008
  • Dorothy Fremder
    Dorothy Fremder Jul 07, 2008
    An a/v selector is a small box that has multiple connections on it. It allows you to connect video game units (sometimes multiple) to your television. It also has a wide slection of outputs, so you can hook up pretty much any type of television. You can purchase them at most any type of electronic store or online electronic retailer.
    I hope this helps!
    Dorothy
    Go Ahead. Use Us.
Why is there no sound when I use nintendo on my Sanyo tv?
Nintendo64 Sound ' Nintendo Tech Forums
techforums.nintendo.com > ... > Discussions
Jan 30, 2013 - 6 posts - ‎2 authors
I have recently started playing my SNES and 64. I am playing ... However, when trying the 64 I get picture but no sound. I am using an ... I hooked the 64 up to a Sanyo tvusing the adapter and it worked just fine. My Samsung ... Connecting NES & SNES To A Modern Flat Screen TV ...
Jul 10, 2014
Nintendo 64 on Samsung Smart TV -... ' Nintendo ...
Dec 19, 2012
Wii U not Outputting to TV ' Nintendo Tech Forums
Nov 17, 2012
How to connect Wii to Sanyo Tv? ' Nintendo Tech Forums
May 29, 2012
More results from techforums.nintendo.com
Sanyo HDMI issue - Forums - CNET
Jan 13, 2016 | Sanyo Televison & Video
When turning on my N64, the power light turns on and I have a standard AV cable hooked up, but the video will not come through on the TV.
Step 1:
So you've eliminated the possibility of bad cables. Now you need to eliminate the TV and the Nintendo 64 itself.
Step 2:
For the TV, you can try another TV or make sure that you have the TV set on the right input.
Step 3:
If you can't make it work on an additional TV and you have made absolutely sure that the TV is setup correctly, then you may be looking at a broken Nintendo 64.
Jan 23, 2013 | Nintendo 64 Console
Cant get nintendo 64 hooked up to flat screen
Wow, the classic Nintendo 64. That was my first gaming system. I do know that the 64 has default RCA cords (Red, Yellow, White). They are required to be inputed into your TV. Make sure the 64 is plugged into a power source and that it turns on. Make sure that your game actually works. Clean out your 64 by using a can of compressed air, do the same to your game.
Finally try to start it up.
If I helped in any way please rate me and help me out.
Thanks,
Brandonmxb
Dec 11, 2009 | Video Game Consoles & Games
Nintendo 64 to jvc hdtv
Check all of your plugs, make sure they are clean. Make sure the game that you have inside the system is clean and free of dust as well as the game connector port on the system. Make sure you are on your A/V channel. If all else fails, you ma have to gt a new A/V plug. When I got my Nintendo 64, I tried to plug it in to my TV using the plug that came with it, but it did not work. I soon found that the Playstation 2 A/V cable that I have also has two additional cables to it, and one of them works in the N64 system. So, I tried to play the system with that cable plugged in, and it worked, so I would suggest buying a new A/V cable that works in the N64 system.
Hope this helps!!!!!
Please Rate
Jun 28, 2009 | Nintendo 64 Console
My nintendo 64 wont workon my tv!!
First you must be sure that the connection on your tv is securely connected.
Mar 08, 2009 | Nintendo 64 Console
Says unusable signal when trying to hookup my Nintendo 64.
Here are a couple of things to try. Go into the menu and make sure that you have the "ANTENNA" selected instead of "CABLE". Also make sure that the channel that you are using (3 or 4) is programmed into the memory of the tv. If not, use "auto program" in the menu to program the channels.
These newer tv's are not the same as older tv's. If none of that works, put a antenna amp on the output of the nintendo and then plug it into the tv. This should fix it.
Nov 17, 2008 | Televison & Video
N 64 does nothing
Well its a power supply failure symptom for this to happen now.
Apr 26, 2008 | Nintendo 64 Console
N 64
Well I think that its broken then like it sounds like a power supply issue or and a laser assembly failure so you will just have to buy a new one then.
Mar 05, 2008 | Nintendo 64 Console
Nintendo 64 HDTV
I am not an HDTV expert but I believe they are all backwards compatible so the fact it is HD should not be a problem. Have you tried a vcr or dvd player on the same hook ups? It is possible you are trying to use a video input that is already in use? I know on my TV I have the DVD hooked up with an S-video cable to "Video 2". Right next to the S-video hookup are the red, yellow, white RCA jacks. On my TV these can't be used when the S-video is in use so I have to have the games hooked up to the front panel "Video 3". I would disconnect everything and try hooking the N64 up in each input to see if you can find one that works.
Mar 02, 2008 | Nintendo 64 Console
Nintendo 64 Console Logo
231 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
