Question about RCA CDRW120 2-Disc CD Recorder
CD: UNRECORDABLE
THERE ARE TWO LOCATIONS, THE ORIGINAL GOES IN 'A' THE COPY GOES IN 'B' --- AS SOON AS THE RECORDER READS THE BLANK DISK IN B, IT GIVES MESSAGE: UNRECORDABLE CD. HAVE TRIED 5-6 DIFFERENT DISKS OF VARIOUS MANUFACTURES --- CD-Rs this sounds like the cd ur trying to copy might be copyprotected is this possible ? NO, HAVE COPIED PRIOR TO NOW AND HAVE TRIED TOW OTHER ORIGINALS FROM WHICH I HAVE MADE COPIES if not copyprotected is the source cd a plus or a minus cd sometimes this will happen depending on source media DO NOT UNDERSTAND YOUR USE OF TERMS: PLUS/MINUS/SOURCE MEDIA . its also possible that the origional cd is slighly damaged meaning the burner cant read it HAVE TRIED SEVERAL ORIGINALS, INCLUDING A COPY OF ORIGINAL, SAME RESULTS. try testing with a simple project that will help verify if laser has gone out of alignment also try to see if your computer will read the origional disk HAVE TESTED BY PLAYING ORIGINAL IN A AND B. ok good luck
    Novelist:
  • 126 Answers
Source media being the disks that you buy to copy to ok , theres cd s diferent cd-r and cd+ r did u try to use _ and + disks ?
will it work in your computer ?get back to me ok
Posted on Jul 02, 2008
I put in a blank or recorded disk ,and the screen message is " unknown disk", and ejects the disk. I have used different blank disks,with the same result. Seems it is not " reading" the disk. Probable...
are you sure the drive is a read-writer? some optical drives are read only. If its not a writer and you put a blank in, that is what it would do.
If you put a real and recorded disk in(not a copy) and it says unknown disk, the eye is dirty. Cleaning the drive will be the next step.
Feb 02, 2018 | Televison & Video
COPT CD
I think you just answered your own question... Did you say that when i you put in a blank disc, it says blank disc? Thats correct. And whats is a B-Deck?
Oct 06, 2008 | Sony RCD-W500C 5-Disc CD Recorder
" Unrecordable" CD message on RCA-cdrw120
this sounds like the cd ur trying to copy might be copyprotected is this possible ? if not copyprotected is the source cd a plus or a minus cd sometimes this will happen depending on source media . its also possible that the origional cd is slighly damaged meaning the burner cant read it . try testing with a simple project that will help verify if laser has gone outof alignment also try to see if your computer will read the origional disk ok good luck
Jul 01, 2008 | RCA CDRW120 2-Disc CD Recorder
?Is there an easy way to do backup on a Dell pc?
buy a hard disk (blank) the same se physically and in capacity as the one in your computer. Set this up to be a second hard disk or as an eternal (USB) hard disk for your computer.
Obtain from the internet a program for clones (of hard disks); create a CD from this; ensure your computer is set to boot from CD first.
Insert the CD into your CD drive. Restart your computer.
Proceed to clone FROM your original hard disk TO your new, blank hard disk. BE CAREFUL THAT YOU DO NOT CLONE THE BLANK DISK TO THE ORIGINAL DISK ELSE YOU WILL HAVE YOU WILL NOTHING. This could take hours. Your should ensure your PC is not interrupted during this process.
At the end the process you should be left with your original unaltered hard disk, plus an identical copy of it, which can be inserted in place of your original if that goes wrong.
This is just one way of backing up.
21.December.2014
May 24, 2014 | Dell Dimension Computers & Internet
Goes straight to burn and doesen't copy
Which Program? There is a difference between Burn and Copy.
Copy means you have a CD or DvD that already has something on it such as a music CD or a movie DvD and you want to copy it. The system normally reads the CD or DvD and copies the contents to disk then asks you to put in a blank CD or DvD to make the copy.
Burn means you have Data Files, Documents or Music that is already on the disk drive and you want to put it on a Cd or DvD. Normally you just put in a blank CD or DvD then either Drop and Drag, Browse or Copy and Paste the files you want on the CD or DvD.
Mar 30, 2012 | Computers & Internet
Pansonic DMR-EH55 DVD Recorder,
You need to reinstall software on your dvd
Apr 01, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
I am unable to engage the record button, the display reads "unreadable or unrecordable disc"
There are several types of blank discs (CD-R, CD-RW). This unit only handles the CD-R discs. Unfortunately, this particular unit is even fussy about the CD-R discs it does accept. Even more unfortunately, there is no way to determine which will be accepted and which will not work. At this point, I can only advise you to try CD-R discs from a different manufacturer. Read the first review on amazon.com. Same issue I have had. Sorry and good luck.
Jul 24, 2011 | Koss CDR200 2-Disc CD Recorder
Will not read blank disks
IT could be youre using a different type of CD-R , MAKE sure CD PLAYER matches with the correct CD-R format eg. CD-R- CD-R+ , CD-RW , etc. thanks AJ
Nov 19, 2009 | Office Equipment & Supplies
RCA CDRW120 2-Disc CD Recorder Logo
309 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
