Wireless connection I get a message that says configurationin set up is not the connection I signed on to.
  • 47 Answers
HAI , CLICK START THEN GO TO CONTROL PANNEL .SELECT NETWORK CONNECTIONS .THE DEFAULT CONNECTIONS ALL ARE DELETED AND CREATE A NEW CONNECTION , RESTART THEN CONNECT WIRELESS CONNECTION.
Posted on Jul 01, 2008
HI there - Are you using windows to configure the connection?? I always suggest that you do becasue I find other 3rd party software isnt always as good / easy to use.
try going into your wireless settings
Start >> Connect To >> Show all connections >> Right click on Wireless network connection >> Click Wireless Networks tab
Ensure that "Use windows to configure my wireless network settings" is checked.
How do you connect chrome to a wireless printer
hi jeanne.
this is all i could find out,if this does not work go to the link at the bottom.
  1. Launch Google Chrome on the computer attached to the same network as the printer. ...
  2. Click the Menu button.
  3. Go to Settings.
  4. Select Show Advanced Settings from the bottom of the screen.
  5. Click the "Sign in to Google Print" button. ...
  6. Tap Add Printer(s) The message will change instantly.
More items...
How to Print From a Chromebook - Google Cloud Print - LAPTOP
How do you connect chrome to wireless printer Google Search
Nov 18, 2017 | Chrome Office Equipment & Supplies
We cannot sign on to the playstation. we are getting error message 80710092
If the PS3 can sign on when directly connected to the modem, there may be an issue with the router or just settings on your playstation. Make sure that in the PS3 under network settings you have enabled the connection you are using. If it is a wireless connection make sure you have copied the setting on your router and computer. You may have security enabled. Test if you can browse using its built in browser. If it can but would not sign in, check the setting of your account. It may just be an incorrect user name or password.
Apr 04, 2011 | Computers & Internet
Yahoo messenger keeps signing it self out
Your internet connection is not stable.
That is why it always log out every time you signed in.
If you are using a wireless internet connections.. I suggest you disable your firewall settings.
May 18, 2010 | Yahoo Messenger
I just set up a new WRT160N wireless router. The PC connected to it works fine. My son can not connect to the wireless connection, even when he is 10 feet from the router. The response is " Unable to...
If you are trying to connect to the wireless network, then first you should know all the wireless settings of the router ( SSID , Security key or password).
If you don't the wireless settings of the router , then you will need to access the router set up interface.
On the set up page of the router you will be able to find the wireless settings of the router.
Once you have the wireless settings of the router then you just need to connect to the wireless network on your computer.
For Windows XP -
In case of windows XP computer you will find the wireless network connection Icon In the bottom right hand corner. right click on it and go to the option " View available networks ". You will be able to see your wireless network. If you do not seethe icon there , then try START ==> Control panel==> network connection. You will find the wireless network connection option.right click and go to " View available networks ".
If you get the message " Windows can not configure this wireless network " , then there is another software utility on your computer which is managing your wireless network. You will need to use that utility to connect to the wireless network. Suppose you have Linksys adapter on your computer , then there must be Linksys utility on your computer which can connect you to the wireless network. if you are not able to connect using that utility then you can switch over to the Windows Utility.
If you get the message " NO wireless networks are found in the range " , Make sure that the wireless switch on your laptop is turned ON. On the laptops there might be a wireless Switch that you will need to turn on. On Some laptops the wireless switch may be the combination of Fn + F2 Or Fn + F5 Or may be different than that. Once you turn on the wireless switch you will be able to connect to the network.
If you seethe wireless network and you tried to connect to the wireless network , some times you will get the message " Waiting for the network to be ready ". That means you might have tried to connect to this network before with different wireless settings . In this case you will need to remove the network from the preferred networks and try to connect again.
WINDOWS VISTA/ Windows 7
In case of windows You will find 2 computer icon in the bottom right hand corner.Right click on it and go to the option " Network and Sharing center ". Once you open the network and sharing center you will find the option " connect to the network " in the top left hand side. Click On connect to the network and you will see the wireless network that you want to connect. If it secured network then type the network key or passphrase and you will be able to connect.
If you get the message " additional log on information required " then you will need to add the wireless network manually.
If you get the message " settings saved on this computer do not match ..." then you will need to remove the network from the preferred network list. Try to connect again.
If you get the message " Press the configuration button ..." , On the same window at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
If you see " Enter PIN number " , then at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
For MAC OS
In case of MAC OS, you will find the AIRPORT icon the right hand top corner. If you click On it, it will try to connect to the wireless network. If you network is secured then it will ask you for the wireless network key or password. type the key and it will connect you to the network.
If you get the message " error joining the network " and if the wireless security type is WEP, then try to connect to the wireless network again. It will ask you for the network key / password again. Now this time enter $ sign before entering the network key . It will connect you.
Click Here for more info
Jan 02, 2010 | Linksys WRT160N Wireless Router
How do i turn on the wireless function on my router
For Windows XP -
For MAC OS
Dec 22, 2009 | 2wire 2700HG-B Router (2700HGB)
How do you set up the wireless
For Windows XP -
For MAC OS
Dec 19, 2009 | NetGear WGR614 54Mbps Wireless Router...
The netgear works when plug it to netgear to compter bt by wireless it dose not work what do i do
For Windows XP -
For MAC OS
Dec 13, 2009 | NetGear WGR614 Wireless Router
Wireless connection for Win 7
For Windows XP -
For MAC OS
Nov 25, 2009 | NetGear DG834G Router
I want to connect my iPhone 3G to my home wireless network using WRT54GS I have found the wireless security tab with the passphrase and Key 1. My iphone ask for a password. I have tried different...
The security type on the router is WEP.
In this case you will need to use the key 1. that will be the network key for your wireless network.
Check just next to the wireless security tab , you will see wireless MAC filter. It must be disabled. If it is Enabled then disable it and save the settings.
When you try to connect using the WEP key 1 , do you get any error message ?
If you get any error then try $ sign and wep key1.
Nov 23, 2009 | Computers & Internet
Wireless switch is set to off
hi,
have you tried using the Fn(key)+ the key that shows the wireless sign you need to press both keys together to turn on your wireless
have you installed the wireless utility that comes with the dell laptops because the the key combination will only work then
here is a helpfull link
http://tinyurl.com/cujy88
Further queries are welcome
if you think my solution was helpfull please do rate me
Mar 28, 2009 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
737 people viewed this question
David Payne
David Payne
