Question about Compaq MV 540 15" CRT Monitor
Brightness control+blurrness of images+
Problem:-
OSD shows
Brightness lavel=0 + Contrast lavel= 100% =Brightness very high
imagest looks blurr. not sharp
please suggest me the proper solution or send me service manual .
model no -MV540
serial no- 047BA26TD261
Manufactured November 2000
***'y no. -153722--005
Spares no.-154798--005
other no is BH68-00291F-03 PL
    Genius:
  • 1,605 Answers
No can do. you monitor is dead in the water.
lost of focus, and intensty. all point to one thing.
by the way, do you have the correct video driver installed???
Posted on Oct 22, 2008
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
The images produces on my web cam are blurr and can't be viewed. if you pass an object infront of it you just see a shadow.
most webcams have a focus ring on the front of them, try adjusting that ring, turn clockwise and counterclockwise to adjust focal point, the other thing may be the brightness setting in the control panel for the camera, open control panel , look for "cameras" locate your webcam icon , then look under properties. There should be settings for contrast.. brightness. color ect.
Aug 28, 2010 | Computers & Internet
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
HOW DO I BRIGHTEN UP MY MONITOR SCREEN?
hi,
you can adjust the contrast and brightness of the screen accordingly using the following instructions. Please select the right combination of brightness and contrast according to your desire.
  • Please check out controls in the bottom of your monitor, below the scree. I have provided the image below for your reference.
  • In this the fourth option is OSD menu. Please click on it and you will scoll down to options .
  • you can see options called "brightness and contrast". I have added picture for this too!
9b04c60.jpgOnce you go that page,use the menu to enter! then use the 2nd and 3rd button to adjust the brightness. Now your job is done.Please click on 1st button to exit. If you need more assistance in this, please write back to us. Please rate my solution as helpful!
Apr 02, 2010 | Acer AL1715 17" LCD Monitor
My LG Flatron Wide Monitor is set for 100% bright, which washes out the image. How can I adjust the brightness? L204WT
Does this monitor have an OSD (On Screen Display),
and a button to activate the OSD?
Does the OSD have the capability to adjust the brightness?
Oct 29, 2009 | Computers & Internet
How can I adjust the contrast on my laptop, I can't see very well
Hold the Fn key down, then press the Right Side Arrow key to increase brightness. (Bottom of keyboard, 5th key from the right)
Granted, that doesn't increase the contrast, it increases the Brightness.
Should the brightness not increase to a level that you feel is comfortable, then I suggest you have a Backlight, or Inverter going bad.
Sep 14, 2009 | Aspire Acer 7520-5071 Notebook
OSD Brightness on screen constantly
pls change the contorl buttons ( no 4 )
Jan 04, 2009 | Philips 190B6CB/27 19" LCD
On the side of the monitor are 6 little buttons. What is the function of each of these buttons.
I found a user guide for a CMV938A that I expect the buttons to be the same.
Here is a link to the manual: CMV938A User Guide
The buttons are described on page 6 of the manual.
1.
Power On/Off button and indicator LED.
Green: Normal.
Orange: Power Saving.
Off: Power Off.
2.
Enter and exit the OSD menu.
3. O/>
•* Quick brightness adjustment and increase contrast/brightness.
•* Move selection right when OSD is displayed.
4. O/<
•* Quick contrast adjustment and decrease contrast/brightness.
•* Move selection left when OSD is displayed.
5 Auto/▼
• *Automatically optimize positions, phase, and clock when OSD is not displayed.
• *Move selection down when OSD is displayed.
6 Turbo/▲ •
*Switch between picture, text and economy modes.
• *Move selection up when OSD is displayed.
Nov 05, 2008 | Computers & Internet
Compaq MV 540 15" CRT Monitor Logo
143 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
