Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Earring went through the wash. Onec came out and the other is missing
It is not caught in the agitator. Where should I look next
    Sergeant:
    Champion:
  • 324 Answers
Under the tub.you have to take off the agitator/the cabinet then the spanner nut,then the basket ring,then the tub
hopefully it did not drain out.
Posted on Nov 05, 2008
Simpson washing machine
you need a 10mm socket and some extensions and a ratchet take the fabric softer filter out and undo the ,bolt at the bottom of the agitator and lift out
May 28, 2017 | Simpson Washing Machines
Sock stuck under agitator
Good Afternoon Haley - Based on the model number posted above, it shows that you are speaking about a front load washer. Is that correct? If so, then generally speaking front load washers do not have an agitator. If a sock is caught underneath it is typically because it got caught in between the door and drum because the seal is either damaged or off the track. If you have a top load washer, you may try to twist the agitator and then pull it out to remove it, as you would for maintenance cleaning.
Jun 24, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have suspenders caught below the agitator. I want to remove agitator to free the cauight suspenders.
some models the agitator is held in by bolts and you have to pop off the top of the agitator to unscrew them. and some models the agitator just slides up.
Feb 17, 2011 | Washing Machines
Fine garment caught under centralrotor has black mark on it , is this grease?
It is not grease. Under the agitator there will be a sticky buildup of detergent and dirt that has stuck to it. Overtime this buildup can become quite a lot. When your garment became caught up under the agitator, it was becoming stained with this buildup.
Jan 09, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Clothes get caught under the agitator and tangled around the agitator and have to unravel the clothes from the agitator
Check the rubber gasket around the agitator is not worn. If it is get a replacement and insert it in snugy.
Aug 16, 2010 | Whirlpool LSQ8543J
I have whirlpool model LSR7233EQO and one belt of cotton stuck under the propeller
If you are referring to something being caught under the agitator, you can remove the agitator easily, by following these steps:
1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4. Remove the agitator by grasping the bottom flange and carefully pulling straight up.
With the agitator removed, you can easily retrieve anything caught underneath. When reinstalling the agitator DO NOT overtigthen the center post nut. Tighten until snug.
If this is not what you are referring to, please post back and let me know, so I can provide you with better assistance. I hope this is helpful to you.
Feb 28, 2010 | Washing Machines
Clothes are caught under the agitator. How can I
Remove the top part of the agitator or the cap and you should find a bolt in the center. Remove the bolt and pull up on agitator.
98702 is not the model # of the machine. you should find the model # either on top of the machine or in the dryer door area around the frame.
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
Makes a grinding noise when on wash
HOW OLD IS THE UNIT ? IT COULD BE THE TRANSMISSION BEARINGS. IF UNIT IS MORE THAN 5YRS BUY A NEW MODEL
Aug 19, 2009 | Washing Machines
Washer not draining - foul smell
It is so nice to get positive feedback from the people we work so diligently to help. Thank you, thank you, thank you!! And enjoy those earrings!!
Jul 15, 2009 | GE WSXH208A Front Load Washer
Agitator loose after dog replacement
Try RepairClinic.com thats where i get all my parts
Mar 02, 2009 | Whirlpool LSR7333 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
112 people viewed this question
Dan Webster
Dan Webster
Sal De
