Question about Nikon Nikomat FT 35mm SLR Camera
Nikkormat FT Took it  my Dad's Nikkormat FT out of storage and my 19 year old was looking t it. Now the timer button is halfway down and the shutter button is down. I have opened it and wound film in to and nothing. I can not move the timer lever down any further. Help!!! Also the light meter does not work either. Thanks, Mea
I have a Nikkormat FT, and I can assure you that there is no "timer" button on this camera. There is, however, a timer lever to the left of the lens if you are looking at the front of the camera. As for the light meter, have you tried moving the film advance lever to the "cocked" position, since that turns on the meter.
Posted on Jun 30, 2009
SOURCE:
I don't know how to get/find/use the timer on my camera FINEPIX SL245
Press cursor-down (marked with a one-handed clock) to bring up the self-timer menu, use cursor-left/right to select the desired delay, then press the MENU/OK button. Start the self-timer by pressing the shutter release button as usual.
Full details are in the "Using the Self-Timer" section of the manual (page 39 in my copy). If you need a manual you may download a copy here.
Jan 28, 2013 | Cameras
How to turn on self-timer
Press left on the multiselector (the one-handed clock icon). Use up/down on the multiselector to select the desired delay. Press the shutter release button halfway to focus and meter. Press the shutter release button all the way to start the self-timer.
Full details are in the "Taking Pictures with the Self-timer" section of the manual (page 32 in this copy).
Jan 14, 2012 | Nikon Coolpix S3000 Digital Camera
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
How to self photo?
To use the self-timer, press cursor-left (marked with a one-handed clock). Use cursor-up/down to select the desired self-timer mode. Press the shutter button halfway to focus, then press it the rest of the way to start the self-timer.
Full details are in the "Taking Pictures with the Self-timer" section on page 32 of the manual.
Mar 04, 2011 | Nikon Coolpix S3000 Digital Camera
Nikkormat 35mm SLR light meter not working!
1) Clean the battery contacts and put fresh battery.
2) Open the top cover and clean the meter switch ( located and the wind cam )
3) Meter needle maybe stuck at the rest position. Remove the stopper and replace or clean.
4) If none of these help, check the meter cells and resistor band under the shutter dial behind the lens mount ( hard to do.)
Jun 14, 2010 | Nikon Photography
Trying to figure out how to use the timer on my Nikon Coolpix S570
Press the self-timer button (left of OK).
Press up or down to choose either two second or ten second delay.
Frame the picture and press the shutter release halfway to set focus and exposure.
Press the shutter button the rest of the way. The self-timer starts, the remaining number of seconds shows on the display, and the self-timer lamp blinks.
After the picture is taken, the self-timer reverts to OFF.
To cancel the self-timer, press the shutter release button again.
Fuller details can be found in the manual under "Taking Pictures with the Self-timer."
Jan 15, 2010 | Nikon Cameras
I would like to know how use use the selftimer on the olympus 310
Page 72 and 73 of your advanced manual explains how to use this feature.
Basically you can have the camera selected to any mode on the mode dial - press Ok - right arrow to Mode Menu - highlight camera tab and left arrow over and then down arrow to the symbol that looks like a clock - this is the self timer option. right arrow over and make sure you select it to on - and then press ok.
Press the shutter button fully to
take the picture.
• Pressing the shutter button halfway locks
the focus and exposure.
• The self-timer lamp lights for
approximately 10 seconds, then starts
blinking. After blinking for approximately 2
seconds, the picture is taken.
• The self-timer mode is automatically canceled after one shot.
May 08, 2009 | Olympus SP-310 Digital Camera
I want to have the camera take a pic of my family on its own
Yes. You can even choose between 2 seconds and 10 seconds. Put the people in the shot. Focus the camera on them by holding the shutter button down halfway, and without releasing the shutter button, press the button all the way down to start the self-timer. (That's what the manual says. I go into the menu on the camera and set it up that way.) To do it from the menu: when the camera is on, hit the menu/ok key. The self-timer mode will pop up. Hit the right arrow. Here you can choose between the 2 and 10 second timer options. Select one. The timer won't start until you have pressed the shutter button halfway to focus and press the shutter button all the way down as stated earlier.
Dec 16, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Nikkormat
This is one of the `good old uns` the most likely cause the timer has jammed from not being used not much you can do without a strip down.if your in the UK send me an email and will repair for you.SUPER8.
Jul 01, 2008 | Photography
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon Nikomat FT 35mm SLR Camera Logo
197 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
