Question about HP LaserJet 9500n Printer
Clean sensor Your response to a problem with a clean sensor error was----The sensor it refers to is the density sensor located inside the machine via the right hand door. Open it and clean the large sensor in the middle. If this doesn't work then clean it with a solution and a soft cloth.--WHAT DOES THE SENSOR LOOK LIKE? We have the same problem but do not know what we are looking for. Any help you can provide will be most appreciated. Please respond to melinda.prince@lamar.edu Thank you!
Clean the sensor that is located inside this part.
Don't forget clean the LED in the middle and the Sensor in the sides.
Posted on Oct 22, 2008
I had a problem my color laserjet printer 8500dn that is asking to clean density sensor I don't no how to do it please help
Hi Elias, The link below is a user manual for a color laser jet 8500, 8500n, 8500dn, I had a look and the answer to your question (Clean density sensor) is on page 155 (To clean the density sensor
1 Open the upper right door.
2 Use the brush located next to the sensor to remove all toner particles from the sensor)..... This WILL Help...CHEERS..
http://h20566.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00656644
Mar 30, 2016 | Office Equipment & Supplies
Error code cf30 in toshiba 3511 what its mean and how can fix it
(CF30) - Reference plate detection voltage abnormality: The output
value of the color auto-toner sensor against the reference plate
is out of a specified range at the light amount correction during
an auto-toner adjustment or when a print job has finished.
Your color auto-toner sensor and reference plate are located under the input tray cover on the left side of the copier when you are facing it. It is on a bracket that hangs down into the copier and sits close to the revolver inside the machine. It is an optical sensor and if either it or the reference plate get stained with toner it will give you this error message, you may attempt to clean them with rubbing alcohol.
This error message may also occur if the solenoid that drives the reference plate is faulty so you will need to check that as well.
I would sincerely recommend that you get an authorized toshiba technician to take a look at the machine for you as this is a fairly difficult problem to fix right.
Sep 29, 2010 | Toshiba E-Studio 3511 Color Copier
WHAT IS DENSITY SENSOR IN LASERJET 8500
The Density Sensor is located inside the right upper door and senses the colour calibration pattern for each colour formed on the transfer drum during a calibration cycle. Press GO. Print a configuration page and then troubleshoot as an Image-quality problem as instructed in the user manual. Check the transfer guide for cracks and replace if necessary. Check the event log for errors numbered 54.00.0<X> the X indicates, 5-sensor abnormality, 4-Cyan, 3-Magenta, 2-Yellow, 1-Black. The last 3 error codes should be seen on the Configuration page.
Dec 29, 2009 | HP LaserJet 8500 Color Printer
Our Trusty steed HP 8500 has just started to print a thin twin line and other spurious marks on the top side of prints. Today i replaced the drum / fuser / other bits but no difference any ideas?
I have looked at the manual but there are so many possibilites! You can download the manual here and go to page 148 (PRINTING QUALITY PROBLEMS).
Initially I would follow the directions for clearing drum related errors:
Dark or white lines or streaks in all colors, including black.
Print the configuration page five times. The defect should clear
with continued printing. If the defect does not clear, turn the
printer off and on to reset the printer’s density calibration. If the
problem persists, replace the imaging drum. For more
information on replacing the imaging drum, see the installation
guide included with the drum kit.
Then clean the density sensor.
from the sensor.
Note
You can also use a hand wipe to clean the
density sensor. To prevent scratches on
the sensor, do not use any paper products,
such as tissue or paper towels, to clean the
sensor.
3 Close the upper right door.
It could possibly be a problem with the transfer drum.
I am sorry this is not of much help!
Nov 13, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Error COF30
toner sensor cannot b cleaned have to replace it
Jun 22, 2009 | Minolta EP1083 CS/PRO Copier
Dp 4530 error code E03-40
e3-40 usually appears when the copy density sensor is dirty. it is located at the bottom of the drum unit. you may pullout the drum unit from the machine and disassemble it to clean the copy density sensor board. it is a small PCB that has two proximity sensors.
pls. keep in touch if you still need an assistance
Oct 09, 2008 | Panasonic Workio DP-4530 Copier
E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Jun 19, 2008 | Panasonic Workio DP-3520 Copier
How to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
particles from the sensor.
Jun 06, 2008 | HP Color LaserJet 8550dn Printer
Aficio color 6513 id sensor location, td sensor location
toner density sensor is located in the developer unit. either the sensor is not reading cause something is covering it or it has poped so it can not reference any longer.
Oct 17, 2007 | Ricoh 6513 Copier
Problem
The sensor it refers to is the density sensor located inside the machine via the right hand door. Open it and clean the large sensor in the middle. If this doesn't work then clean it with a soution and a soft cloth.
Thanks J
Oct 02, 2007 | HP LaserJet 9500n Printer
HP LaserJet 9500n Printer Logo
1,454 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
