Question about HP DeskJet 960c InkJet Printer
Hp960C leaking ink
Hi my printer is leaking ink, I think its from where the cartridges get cleaned. How do I get the cover off!!!!!???
Thanks
  • nanagin Jul 01, 2008
    no it wasn't ink cartridges leaking, it was that pad that catches ink when you "clean print cartridges". I got the lid off-the one you open to change cartridges and to the right was the little well....that is the well that overflowed and there was a chunk of dried(somewhat) ink that was 2x2x1/2 inch thich that I pulled off of the sponge and it still had a LOT OF ink in bottom...I gave up and just pitched the printer after getting that LOT OF ink EVERYWHERE. Thanks for trying. :)
    Sergeant:
  • 234 Answers
1. If you have them, go ahead and put on your latex or close fitting gloves. Ink generally gets everywhere and can be hard to clean off your hands. It’s important to not work on a printer that’s plugged in. However, sometimes certain inkjet printers will not let you change the ink unless the printer is plugged in. So, if this is the case, go ahead and life the cover of your inkjet so that the cartridges can be removed. Once that’s done, unplug the printer.
NOTE: Be sure not to touch the metal part of a inkjet cartridge, because the natural oils on your hand could inhibit the communication of your cartridge and your printer.
2.
To clean the inkjet cartridges, check to see if your cartridge’s have both ink and a print head together.
Together (most common):
Take a paper towel and fold it in fourths. Then add either alcohol (preferred) or Windex to one side of the paper towel. Now, wipe the bottom of the cartridge on the paper towel to clean off the print head in a flower like fashion. It is normal that ink comes out of the cartridge even after you think it’s all clean (that’s what it’s supposed to do).
Separate (less common):
Do not clean the ink cartridges themselves. Since they doesm’t have a print head and generally don’t control the amount of ink that flows out the bottom, you can get pretty messy if you tried to clean the ink itself. Take the print head and separate it from the ink cartridges, then follow the above directions to clean the head.
3.
Now take another paper towel and fold it again in fourths. This time spray a thin layer of Windex on the paper towel and clean the ribbon if it has any major ink blotches on it (see picture to better understand this step).
Whenever a printer finishes its document, your ink “rests” or docks usually on the right or left of the printer. Over time, this area can harness a ton of ink mixed with paper dust. This makes a gooey substance that’s can cause big image problems on the paper since every time you print, you run the chance of hitting or docking on this mountain of gooey ink. To clean, we’re not going to use a cleaner, because if you can see a buildup of ink, generally, it’s much too hard to get to and can be very messy. In the picture, I’ve highlighted where this printer’s “reserve” is starting to build up.
4.
After a while of printing, you may notice that the inside of your printer has a thin film of ink inside everywhere. Although it doesn’t really matter when it’s on the plastic, this can affect the oil on the stabilizing bar, making it harder and harder for the print heads to move. Sometimes it gets so bad that you can hear a “crunch” or “grind” and the end of a printing job. It may appear that the printer isn’t aligning right or can’t dock, but sometimes the lack of oil is the cause.
Posted on Jul 01, 2008
  • ra ja
    ra ja Jul 01, 2008
    then,
    To oil this bar, simply put small dabs on different parts of the bar and drag the print mount/head across the bar manually to get a good coating
    5.Once all the previous steps have been completed, you may want to clean the paper pickup assembly if you suspect it has ink on the rollers which causes paper to jam or not feed properly. My printer has a rear access door which is convenient, but other inkjet printers may have hard to reach rollers. I would suggest doing your best in getting at these rollers with a cotton swab and some glass cleaner or alcohol
    6.To clean the outside, take a paper towel and fold in fourths. Spray a thin film of Windex on it and wipe the outside of the printer to your liking
    That concludes this tutorial of how to clean an inkjet printer. Hopefully it will save a few inkjets from an early grave at the landfill
    if you have more doubt!
    visit it!
    http://printerhacks.com/images/IMG_0088...." target="_blank" rel="nofollow" http://images.google.co.in/imgres?imgurl...
I got always the message Print Head not installed
follow these steps:
1.
Turn the open the top cover. Wait for the cartridge carrier to stop moving, then lift the first cartridge out of the printer. Tilt the cartridge forward, then carefully lift it out of the printer.
2.
Examine the electrical contacts on the bottom of the cartridge. Look for any tape that might be covering those contacts. New print cartridges ship with this tape to protect the cartridge and prevent leaks. If you fail to remove this tape, the printer cannot sense the cartridge and it might return a "print head not installed" error.
3.
Remove the rest of the cartridges from the printer. Check them for tape and other obstructions. Also check the cartridges for leaking ink, and clean them if necessary. Discard and replace any cartridges found to be leaking.
4.
Clean the ink cartridge carriers thoroughly, using a soft cloth or a small vacuum cleaner designed for cleaning computer components. Paper dust and ink residue can accumulate in the carrier and cause communication issues with the printer.
5.
Place the ink cartridges back in the printer and close the top cover. Power cycle the printer if the error message does not go away immediately.
in case of any additional help, please revert back
Jun 12, 2011 | Computers & Internet
Hp960c When printer is turned on the on light and middle light flash on and off and the printer makes a chattering noise. the ink cartridges will not move from the right side of printer.
sir ur printer is struck...for how long u didnt use ur printer?
this is what hp site says
if the lights r blinking alternativy
Carriage stall Turn the printer off. Open the top cover and check for any thing blocking the ink cartridge carriage. Turn the printer back on.
Jul 06, 2008 | HP Office Equipment & Supplies
The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
Sorry to hear that.. here are some instructions that should help you out:
Instructions
things you'll need: Microfiber cloth
1. Ink Cartridge Errors
2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
Cartrigde leaked ink to bottom of printer
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
Aug 18, 2009 | Office Equipment & Supplies
How to change ink on epson dx4450
The steps are :-
Replacing the cartridge:
1. Make sure the printer is on and open the printer cover
2. Make sure the printer is paused and the output tray at the front of the printer is lowered
3. Hold down the cleaning button for three seconds until the print head moves slightly to the cartridge replacement position, and the power light flashes when the print head is in position. Do not move the print head by hand, it will be damaged
4. Lift up the clamp that holds the cartridge you want to replace as far as it will go.
5. The cartridge will rise partly out of the cartridge holder. For black ink replacement, lift up only the smaller clamp on the left.
6. Lift the cartridge out of the printer and dispose of it properly.
7. Remove the cartridge from its protecting bag. Remove only the yellow tape seal from the cartridge. The yellow tape seal must be removed. Leaving the tape on when you install the cartridge will permanently damage it. Do not remove the tape seal from the bottom of the cartridge.Otherwise ink will leak.
8. Lower the ink cartridge into the cartridge holder with the label on the cartridge face up and the arrow on the cartridge pointing to the rear of the printer.
9. Press the ink cartridge clamp down until it locks in place. Do not press the cartridge itself.
10. Press the cleaning button. The printer moves the print head and begins charging the ink delivery system. This process may take a few minutes to complete. The power light continues to flash while the printer performs the ink charging operation.
11. Never turn off the printer while this light is flashing. Doing so can result in incomplete charging of ink. Even if you do not press the cleaning button, the printer moves the print head and begins the ink charging process about 60 seconds after you replace the ink cartridge.
12. When the ink charging procedure is finished, close the printer cover.
You are now ready to print.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | Office Equipment & Supplies
HP DeskJet 930c is leaking black ink
The printer primes and cleans the cartridges when the cartridges go to the right side of carriage. Sounds like a cartridge has either leaked or you have used it enough the the ink pool is full, or you have layed the printer on its side or back. From experence, if ink is leaking out of the printer, your probley better off getting anithe printer. I have tried to take the covers off and clean inside print, and it is a messy job.
Mar 06, 2009 | HP DeskJet 930c InkJet Printer
Install HP960C ink cartridge
Visit this link http://h10032.www1.hp.com/ctg/Manual/bpd08651.pdf and download the acrobat manual. You will find all details there...sodeep
Jul 13, 2008 | HP DeskJet 960c InkJet Printer
Black ink line on back of paper
Hi , look some used injection cyrene to suck up the used ink , take cover suck up all ink by reversing injection put in clean jar .after all ink finished cover it try to print from first time some print some black mark after tthree or four times maybe no more.
Jan 08, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Hp officejet r40 cartridge carriage blocked
Not sure about r40's, but look here about the leaking ink solution for G85's and DJ900's: http://www.fixyourownprinter.com/forums/inkjet/22399
There is a guy named BERT who is a master a fixing HP units, and his email can be found in the above mentioned forum note.
Dec 31, 2007 | HP OfficeJet r40 InkJet Printer
HP DeskJet 960c InkJet Printer Logo
190 people viewed this question
Seeker5211
Seeker5211
