Question about Refrigerators
My philips fridge freezer (side by side) keeps clicking as if trying to do something. The issue only goes on for a short period of time and is not consistent in any way.
  • spankychan Jul 01, 2008
    Thanks for the quick reply.
    On discussion with my wife, it seems that the clicking occurs in sync with the temperature display and the sybols on the same panel flashing.
  • 481 Answers
It sounds like it could be a bad (or possibly going bad):
  •  start switch (on the side of the compressor) or
  •  compressor itself
  • the start switch clicks  off usually when the compressor is pulling too many amps or the compressor is overheating.
  • if the compressor is not even running then its probably not overheating.
  • so either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
Posted on Jul 01, 2008
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Our fridge keeps shorting out power supply each time its plug into wall?
It may not be expensive. Lets look at a couple of things. You may ave a wire that is shorting out against the body of the fridge. If it shorts out as soon as you plug it in, that will tell you it is a dead short which is a wire probably touching something else. If it is delayed a short period of time, this usually indicates the compressor or fan is seized up and after a brief time it shuts off to prvent a fire. If it is over 12-13 years old, you may want to consider replacing it. It may be worth it otherwise to repair it. This is a pretty nice frig and may be cost effective to repair.
Mar 02, 2013 | Whirlpool ED5FHAXVY 25.3 cu. ft....
We have an stainless steel side by side Electrolux fridge and the freezer sise is fine but the fridge side keeps getting too warm reaching temps of 70 degrees...We adjust the temp settings and it sometimes...
On a side by side unit, the freezer actually cools the refrigerator side of the unit by the use of a "damper" door or switch. Check this between both doors for any ice blockage or damage and go from there. You might need to contact a professional to diagnose the entire unit if you don't "see" any issues.
Jul 21, 2012 | Electrolux Refrigerators
Amana refrigerator freezer access panel removal
As a plumber... I would initially want to see if it is indeed a leak from the water line. You have defrosted, so there would be water at that time and a short period thereafter. You have had the unit off for two days so it's not been able to "generate" any more ice or even had a chance to malfunction and "try" open the solonoid valve and allow water into the ice maker or water dispenser.... All that being said...
I suspect the water you're see is ultimately from the incoming (pressurized) water line... probably not from the actual ice make line coming into the fridge, but more than likely somewhere "within" the piping of the fridge itself... its very possible something was accidentally damaged during the previous process you just went through-- especially if you removed the door to the freezer. Many fridge's have the water line come through the lower side hinge of the freezer door, not sure if this is true in your case.
Hope this helps, if not it may be applicable to someone else... good luck!
May 17, 2012 | Amana Refrigerators
Not cooling on either side model #106.54606300
When you say it not cooling on either side, do you mean both the freezer and fridge is not cooling? If yes, read further.
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Mar 31, 2011 | Kenmore Side by Side Refrigerator
Freezer suddenly defrosted!
sounds like you may have one that's in the recall..search maytag recall refrigerator and see if yours is one of them.free repair.
Jun 12, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
Jan 12, 2009 | Fisher and Paykel Active Smart® E522BR...
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
Refrigerators Logo
248 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
