Question about Panasonic Microwave Ovens
I need a glass fuse for a Hinari Eclispe EMX799GMSSE microwave,I think this could be an Anti Serge, On the end of the old one it reads; 5KVO.75A
  • Panasonic Master
  • 9,086 Answers
Looking under Hinari Ellipse might help your searches.
Their "Web site" is at http://www.hinari.co.uk/ but I wouldn't bother going there, because this is all it says:
PULSE HOME PRODUCTS LTD
VINE MILL
MIDDLETON ROAD
ROYTON
OLDHAM
LANCASHIRE
UK
OL2 5LN
CUSTOMER SERVICE: 0161 621 6900
SPARES LINE: 0161 621 6855
It's that last number you want, and I would order two fuses, just in case you have a shorted component (like the high voltage capacitor) that will blow the fuse immediately upon powering up.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
Fuse Specifications
Suresh,
Most of the time you will need either a 15 amp or 20 amp fuse for your microwave. You will want a ceramic fuse and if you still have your old one, the amp rating and all info you need will be stamped on one of the silver collars at each end of the fuse. Hope this helps!
Jul 09, 2015 | Microwave Ovens
There are condensation, water drips between the glass on the door of my over the counter microwave/convection oven. Is this a problem? How can I clean this? Microwave is only 6 months old.
HELLO.
Yes.Water can only drip between the glass on the door when the door do not seal properly due to dirt on the microwave door.follow these steps given below to clean the door.
1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
Thanks.
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I purchased a hinari s/s microwave 77505883999 from tj hughes but it had no manual with it or the glass turntable and ring for inside microwave so they told me to go online and put in details of micro and...
Are you sure the number you have given is the model #? It looks more like a serial number. Most of the Hinari model numbers start with letters (eg. MX or EMX)
I found a website in the UK that sells parts for Hinari Microwaves ... > http://www.espares.co.uk/search/microwaves/hinari/p/1095/1032
Hopefully that helps...
Aug 08, 2011 | Microwave Ovens
I was heating something in the microwave and all of a sudden the microwave just shut off - lost all power. It's 13years old. Do you think it's dead?
check for thermal fuse, mine is 20 years old too , these are small in line with the power cord, may need a test meter too and hand tools screw driver and such 1-2 thermal fuses non resettable ... they are 8-10 dls us @ Radio Shack . also some have a glass fuse mounted on circuit board check this
Mar 19, 2010 | GE Microwave Ovens
Hinari microwave instruction manual
Find it here (the Elipse Microwave should fit)
Jan 25, 2009 | Microwave Ovens
Hinari microwave sparked and wont work.....
Check the service section in your manual.
You will get any Hinari manual with the manualfox search engine. Check results here:
http://manualfox.com/link/hinari.htm
Dec 15, 2008 | Frigidaire FMV156DC Microwave Oven
Hinari microwave oven
Thank you.
Visit this page and click Product Support.
A new page will pop up with their contact information.
Dec 07, 2008 | Microwave Ovens
Service
It should be marked on noted on a tag near the fuse holder, but commonly it;s 15 or 20 amps, and it should be ceramic (white or gray).
Aug 16, 2008 | Microwave Ovens
Microwave Ovens Logo
259 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
