Question about Symbol LS 4071 Handheld
No data is transmitted
I scanned the pair barcode and scanned the default parameter. I opened up an excel file and started scanning som barcodes. The scanner seems to work meaning it scans the barcode and I get a short beep but the data is not transmitted. What gives?
  • 1 more comment
  • andyt6886 Jul 22, 2008
    I was told that I need additional hardware. I ended up returning the scanners.
  •  Brian
    Brian Nov 18, 2008
    SAME HERE PLEASE IF YOU FIND SOMETHING OUT PLEASE LET ME KNOW THANKS
  • alphaa Apr 10, 2009
    so what does that mean? I am stucked !  It made the beeping noice, but no data is transmited via the serial cable.
  • 724 Answers
Http://www.barcodehq.com/software.html
I think you need a data base that relates the bar coded bars to what ever it is you set it up to be.
The scanner is just a machine that sees the lines and spases now you need the software that comnnects this machine and translates or shall I say compares what was scanned to what is in the database. Lets say your data is made of just 3 things.
lets say one will relate to blue next to red next to green
We have to scans of 3 different items and we need to know how many and what kind. Now we have a scanned that reads just these colors. our software is running and in standby polling the port waiting for info. We scan it is scensed by the scanned the scannedr sees a color and it will ID the color by a number 1 or 2 or 3 now it is in our data that a number 1-red was read. the endry is noted and that is incremented .... etc. get the drift is it a scensor and you need the data comarison program that is the root.
Posted on Jul 27, 2009
You need software to convert to barcode to text. im in the same boat right now...keep lookin ;)
Posted on Jul 22, 2008
Have an online manual for LS4004 I000. How do I get the scanner to transmit an enter key after scanning a barcode?
try reprogrammimg, it should default after it scans an item to enter whaT WAS SCANNED
Jan 31, 2013 | Computers & Internet
My symbol barcode scanner beeps 4 time while I try to scan. The Manual states that the battery is bad. I replaced the battery & it does the same thing.
This 4 beeps also stays for communication error. Please check the connection to the cradle and also the connection between the cradle and PC.
You can start by pairing the scanner with cradle with the Pairing barcode, then defaulting the scanner to the standard settings - use the barcode "Set All Defaults" from the manual. Then select the right host type USB, RS232 or another.
After this procedure should the scanner work.
Sep 07, 2010 | Symbol LS3578-ER Rugged Barcode Scanner
Will not transmit to Shop and Scan website when transmit button is pressed . drivers installed from cd provided, new usb lead connected and green light shows on scanner, test scan done from barcode on...
Did you ever get it to transmit the barcodes?
I'm having very much the same problem. Got the error 3 message first, then was told to delete the add on in manage add ons. Now i get an error 2.
Jun 13, 2010 | Opticon OPN 2001 Mobile Data Collector...
Getting a MC9090 and 1500 preprinted labels to stick on pieces of pipe. Just need an excel file with the cross ref in it. Want to scan a barcode later and have description come up. Can I do all of this in...
To get scanner to work on MC9090 WM5 and scan into excel, I had to install DataWedge From Here You will need to install this through your ActiveSync That will make it so you can scan directly into excel The setup your data, the you can do a find, to find the cross ref
Dec 10, 2009 | Symbol MC9090-G RFID Handheld Barcode...
I need a default barcode to reset my scanner to accept barcodes automatically with my LS 4000I-I000 scanner
There is no such bar code. barcode scanner scans any barcode and give the result.
scanner can scan in any software. eg. excel,word. dos etc.
Aug 08, 2009 | Symbol LS 4000i Handheld
I would like to transmit EAN-13 bar code without check digit, but closed by ENTER.
If you would like the LS2208 to transmit only the first twelve digits of an EAN-13 barcode followed by an enter you will have to write an Advanced Data Formatting rule using barcodes from the LS2208 Product Reference Guide found here: http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880806apdf&sliceId=&dialogID=114420371&stateId=1%200%20114410810
The barcodes you will print and scan in the order they are listed are:
Begin New Rule
EAN-13 (from the Critera pages of the ADF section)
Send Next 12 Characters
Send Enter key
Save Rule
If all other barcodes require an enter key make sure you scan Scan Options, Data Suffix, Enter (from the same manual or from the Quick Start Guide) before scanning the ADF rule above.
Jul 13, 2009 | Symbol LS2208 Handheld
Where is my barcode after I scan it?
Is the cradle connected to the pc via either usb, serial or keyboard wedge?
If so you will need to first, pair the scanner with the cradle by scanning the barcode on the cradle and second, configure the cradle properly so it transmits the data to the host.
Download the product reference guide from motorola website. You will get all the configuration information you need in there.
Mar 20, 2009 | Symbol LS3578-FZ Barcode Scanner - P/N...
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
Removing leading zeros from barcode???
Prefix/Suffix Dialogs
The Prefix/Suffix Dialogs allows configuration of DataWedge options.
Two data entry fields are used to display and allow entry or editing of prefix and
suffix strings. The prefix string, if present, is transmitted before the data for any
barcode scanned. The suffix string, if present, is transmitted after the data for any
barcode scanned.
The following checkboxes are used to display and allow modification of various
DataWedge options:
Allow escapes in prefix/suffix (default = disabled)
Enabling this option allows escape sequences to be embedded in prefix and
suffix strings. Escape sequences allow non-textual data to be transmitted as
part of the prefix or suffix string. All escape sequences begin with the backslash “\”
character. The supported escape sequences are:
\b Backspace
\f Form feed
\n New line (line feed)
\r Carriage return
Apr 14, 2008 | Symbol MC70
Symbol LS 4071 Handheld Logo
568 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
