Question about Dell Inspiron 6000 Notebook
Dell Inspiron 6000 PC Audio Ports Damaged
Some how i managed to damage the input ports (microphone, headphone) on my laptop. When I plug in a microphone to the microphone jack, and wiggle it around, i get nothing. However, when i plug it into the headset port, and wiggle it around, in one specific spot, i get a connection.
My main question is this.....for me to even be able to listen to audio on my laptop, i have to have that microphone plug in that specific spot....is there a way to bypass this hardware setting to where I can get sound on my laptop speakers without the ports interference.
To get audio and microphone use, i have purchased a USB adapter...however, i would also like to just listen to audio on my laptop speakers
  • 4 more comments
  • qbulldog13 Jul 02, 2008
    Pyrhyc, I appreciate the response. I knew this was the case, and that is what I am trying to bypass. I'm sure there isn't a way to bypass it, however, I'm not a computer tech, so I'm hoping there is possibly. Seems odd that they wouldn't allow a bypass feature, considering the issue I am running into is quite common on laptops.
  • snmslrc Aug 15, 2008
    got the same exact problem with my dell inspiron e1705
  • josephnz Nov 28, 2008
    I too have the same problem. I opend my laptop and checked and I confirm that it is due to the problem of the Jack. From what it looks like the Jack is fixed to the main board and no clue if we can replace it by buying a new jack(If available in Market, please let me know if its is ) Does anybody advice how to replace a faulty headphone jack of Dell inspiron 6000 laptop.
    thanks,
    regards
    Joseph
  • Critical Solutions I.T. Consulting
    Same exact problem...
    I've tried aluminum foil to no avail...I can only get sound if I put the headphone plug in half-way and push straight down...It used to work by gently wiggling, or leaving it in half-way...I've shined a light in and can see 3 brass contacts...one on either side and one at the top near the entrance
  • bijithkumar Mar 31, 2009
    Same problem here. Does anyone know how to repair/replace mic jack?
    Genius:
  • 2,028 Answers
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Posted on Jul 01, 2008
My external audio connection doesn't work
Are you using the headphones jack? Do headphones work from the port? Win XP Drivers can be found here: http://www.dell.com/support/drivers/us/en/19/Product/inspiron-6000
Nov 29, 2012 | Dell Inspiron 6000 Notebook
Do dell computers model number PP20L have microphones
This dell computer does not have a built in microphone.
It has a microphone input jack on the right hand side of the base just to the rearr of the headphone jack and just in front of the 2 USB ports.
Feb 01, 2011 | Dell Inspiron 6400 Notebook
Does my Inspiron 9400 Laptop have build in microphones?
Yes It is. You can check them either in COntrol Panel > SOund or Start > Run > DXDIAG.
WIth regards
FIXYA team
Oct 09, 2010 | Dell Inspiron 9400 Notebook
BUILT-IN MIC ON DELL
Yes, it does, 'evidence' below.
Specs of the Dell Inspiron e1705 Being Reviewed:
  • Processor: Intel T2500 2.0GHz Core Duo
  • Motherboard Chipset: Intel Calistoga i945GM/PM
  • Hard Drive: 100GB 7200RPM SATA (Hitachi TraveStar)
  • Memory/RAM: 1GB (1,024MB) Dual Channel DDR2 SDRAM (667MHz)
  • Screen: 17.0" UXGA TrueLife (1900 x 1200 pixel resolution glossy screen)
  • Graphics: nVidia GeForce Go 7800 256MB
  • Optical Drive: DVD +/-RW with DL DVD+R write capacity
  • Battery: 9-cell (standard size 6-cell, 9-cell extended life optional)
  • Wireless: Intel PRO/Wireless 3945ABG (802.11 a/b/g)
  • User Input: Touchpad
  • Dimensions: 15.5" x 11.3" x 1.6" (Width x Depth x Height)
  • TV Tuner: Optional external USB TV Tuner with remote control upgrade for $104
  • Weight: 8.1 lbs
  • Ports:
    • 6 USB 2.0 ports
    • IEEE 1394 (FireWire)
    • Digital Video Interface (DVI-D)
    • VGA out (monitor out)
    • S-Video Out
    • RJ-45 (Ethernet LAN)
    • RJ-11 (56-Kbps Modem)
    • Audio line out for headphone/speakers
    • Microphone
  • Slots:
    • 5-in-1 Multi Card Reader (MS, MS Pro, SD, MMC, xD)
    • 1 ExpressCard 54 slot
  • Buttons:
    • Power on/off
    • Volume up/down/mute (3 buttons)
    • Media buttons (play, forward, back, stop)
    • Battery charge test button
    • Battery lock and release
May 03, 2009 | Dell Inspiron E1705 Notebook
Microphone input on Dell Inspiron B130 doesn't work
Your jack may have been damaged, or the apple mic may not be compatible. Purchase another pc compatible mic to check. Or you could try a multimedia headset with mic that plugs into your usb port. Take a look at RadioShack for headsets, I saw one in a store near me. and they should have them online.
Jan 27, 2009 | Dell Inspiron B130 Notebook
Sound thru tv
You will need a cord that plus into the headphone jack or speaker out jack on the computer and has rca end to plug into the audio input on the TV.It will look like the one pictured.Please rate this solution.
Jan 17, 2009 | Dell Inspiron 6000 Notebook
D510 how can I hook up to my stereo?
The two ports on the laptop are most likely a mic input and a headphone output.
Connect a cable (stereo) from the headphone output to the stereo input of your amp.
Jan 01, 2009 | Dell Latitude D510 Notebook
Damaged USB ports
You need to goto the nearest service center...
Dec 06, 2008 | Dell Inspiron 6000 Notebook
Headphone
You need to make sure the microphone is working fine because its the microphone which will allow other people hear you.
Thanks
Oct 26, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 5150 no power, no lights
it could be that the ports where you plug in the charger is damaged. if you have an identical or a known good battery that is charged, try to install that and check if it works. you need a motherboard replacement if the system works with a charged battery.
Sep 24, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
2,140 people viewed this question
Alun Cox
