Question about Pioneer Audio Players & Recorders
Amp turns off and say overload - Pioneer Audio Players & Recorders
  • abl7155 Aug 22, 2008
    Due to overload message I purchased a new receiver. Now this receiver also says overload.
    Genius:
  • Pioneer Master
  • 1,550 Answers
My dear friend the audio amplifier IC are damaged you need to change it.
Posted on Jul 01, 2008
It is tripping motor starting on load and tripping
If the pump turns easily by hand and trips breaker, most likely the start capacitor is weak or bad. If the pump is hard to turn by hand then problem is most likely the in-tank check valve is leaking pressure back to the pump causing the motor to overload. If the pump turns easily by hand and the check valve is good and capacitors are good, then use amp gauge to verify overload, if amp gauge shows normal amp draw then most likely weak reset button. Good luck
Oct 29, 2015 | Air Tools & Compressors
Amp keep's sating overload
Have you tried disconnecting all the speakers and inputs and turn it on?
If it still shuts off you have an internal problem, if it stays on, connect one item at a time until it shuts off and that is the problem.
Jan 13, 2013 | Panasonic Technics Sa-gx690 Av Control...
Amplifier overload
You have an overload in the power amp section. I suspect one or maybe more of the devices on the big heatsink has shorted out. Also check that speakers and cables are all good before trying the unit out agian.
Dec 28, 2012 | Audio Players & Recorders
Goulds pump model BGR75 won't reset. Any tips.
If the motor runs but keeps tripping the overload, the motor is bad or the motor is under a big load. Does it pump water? If not, check the impeller and see if there is anything wrong with it. If it does pump water and the motor trips overload, the only thing left to check is the overload. Check the motor's amp draw and if within specs, replace overload. If amps are too high, replace motor.
Aug 22, 2012 | Plumbing
Kicker SX900.2 turns on then says overload and shuts off
Sounds like one or more of the output transistors have gone and the amp protects itself from any further damage.
May 06, 2012 | Kicker Car Audio & Video
My pioneer amp vsx d508 reads overload.what to do?
Sounds like a bad amplifier IC.
Unhook all speakers at the back of your pioneer. turn it on and turn down the volume. If it's no longer in overload you have a bad speaker or speaker wires touching somewhere.
If its still in overload it's prlobley a amp IC and will cost between $25-$60 just for the part if you can replace it yourself.
Dec 27, 2009 | Pioneer VSX-D508
Turn on, in a few seconds Flashing "OVERLOAD"
Overload  usually only appears if you have been using higher volumes for a period of time and this trips to protect your speakers and amplifier. Turning off your amplifier and leaving for a while and it automatically resets. other wise a would check your speaker cabling to see if any wires are  touching shorting out the circuit. Try removing you cables from your amp then turn on. If it turns on without Overload appearing the problem is between amp and speakers. Check your cables at both ends and while at it give them a clean then hook up everything ( Amp should be off) then turn on the amp and see if you get message. If you still get this message you could have  dry/ broken soldering on the inside and the amp is detecting a dc short in the system. This seem to a common thing these days. In which it will be a repair job.  Low impedance speakers or speakers that have a wide impedance swing when they are running at high volume can cause a amp to trip if it hasn't got enough current to drive low impedance speakers. Hope this has been of help.
Nov 17, 2009 | Pioneer VSX-455 Receiver
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
Jul 15, 2008 | Audio Players & Recorders
Jl amp
the overload protector of your unit it so sinsitive try to cutof the overload relay and then observe 20 min. monitor the allominum heatsink the temp. normal
Aug 27, 2007 | Jl Audio 250/1 Car Audio Amplifier
194 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
