Cannot get TV and Magnavox DVD/CD player DV220MW9 to work together. TV alone works fine, when player on get poor picture quality. When TV is set on "AUX" cannot select channels or set programs. Can play VHS but nothing else. Instructions with player are vaque and confusing. Thanks for the assistance.
  • dhkerr720 Jul 01, 2008
    TV is a Magnavox...forgot to mention that also using a Phillips RF modulator set to channel 4 for our area. Just discovered can only get channels 2 thru 13 only with player off, with player on nothing but snow and static on all channels.
    Genius:
  • 1,689 Answers
First off, you may need to check if the RCA ports you are using on the DVD is the same with the TV, like "video out" on the DVD should be on the "Video In" of the TV, there are times that the cable for video out goes to the one of the ports on component in. also you may check on the RCA cable itself check for damages on the entire length because exposed wires can also give out poor quality.
what TV are you using by the way?
Posted on Jul 01, 2008
  • marlon john madrid
    marlon john madrid Jul 01, 2008
    i'm pretty sure your modulator has auto video select, if it does, there is a strong possibility that issue is the connection from the DVD to the modulator, that is just a possibility. lemme know what is the exact model of the modulator so that we will be able to check on what needs to be changed.
    Master:
  • 638 Answers
Check after replacing the communicating wire cods.it sometimes because of these wires.keep me updated.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • hemant somaiya
    hemant somaiya Jul 01, 2008
    dont forget to rate the solution
Why after power outtage dvd player don't work?
A power surge sometimes fries the unit it may have a fuse you can replace on the inside
May 14, 2015 | Magnavox Dv220mw9 Dvd Vhs Vcr Combo Player
I need a manual for a magnavox dv220mw9 dvd player
http://funaiport.com/download/download.php?id=43&brand=MAGNAVOX
Sep 25, 2010 | Magnavox DV220MW9 DVD Player VCR
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Connecting magnavox dvd/vcr player DV220MW9 to a 40 year old TV
What type of Inputs do you have on your TV. (ANT IN, S-Videio, RCA Video,RCA Audio)
If you only have a ANT In or RF Coaxial hook up you will need a RF Modulator
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Wirring up (HDTV) from DV220MW9 to TV
I had the same problem & had to purchase a seperate RF Modulator for $18.
But I still have a problem & can't record TV shows onto a VHS tape, possibly
due to my older TV.
Hope you have better luck than me on recording : )
Dec 25, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
