Question about GPX MW8847DT MP3 Player
Not Connecting! I had it playing just fine for a long time, so then, obviously, it died. So when I went the the computer to charge it, it wouldn't connect. It is not charging nor even connected and not showing on the computer. Plz help me if you can, i would really appreciate it!
  • 1 more comment
  • Sweetduder5 Jul 27, 2008
    Thanks, I'll try that! :)
    I tried it. :( It didn't work. I was reading through this and I remembered, a while back I needed to do a recovery format to it.
    I would like to do that again because it was the same problem and it worked tell now...so I would like to do that, but the problem is, I don't remember how. :(
    Can someone tell me how to do this again?
    Thanks,
    -Sweetduder5
  • m_s_n_is_swe Dec 21, 2008
    never wants to do sync and everytime i plug it in it gives me a window then asks me ot finish then i click finish and it says i can't change the sync setting at this time
    President:
  • 4,402 Answers
Are you charging with the usb port? if so see if you can get a AC Charger
Posted on Jul 01, 2008
How come my digital2 tablet won't open up it's on?
this is a computer question being asked on a auto site try the computer site.
Aug 31, 2014 | Cars & Trucks
2006 jeep commander died when driving
a faulty engine coolant temperature will cause vechicle to stall out during climate changing.
Jul 29, 2013 | 2006 Jeep Commander 5.7
Car ran fine shut it off came back it didn't want to start. started went about half a mile sputered an died wouldn't start back up 1991 subaru loyal wagon
Hi sounds like the typical fuel pump or filter problem with these cars, best way to tell is take top fuel hose off on fuel filter under hood, turn key on ignition (not start) and fuel should pump out, if not its your pump, just beware of doing when engine is hot
Apr 22, 2012 | 1991 Subaru Loyale
I have a 99 dodge caravan. just recently my fuel gauge stop working. Then would start to work. Its like every other day. When I suddenly braked the gasuge went to empty and the automatic locks...
Probably not. Sounds like a bad ground. The ground connecting point for the door is behind the drivers side kick panel, lower left. And the ground for the fuel sending unit is on the drivers side fender well. First I would unplug the connection at the tank (you can usually access this plug without drooping the tank) and check for corrosion. Clean it if any and take a paper clip and bend the tabs a little in the plug to make a better connection.
Jun 21, 2011 | 1999 Dodge Grand Caravan
We have a 2003 dodge caravan and have been having problems with keeping a charge. the alternator has been replaced, so has the battery. several weeks ago I had driven up to 7-11 came out and it would not...
Testing the electrical circuits an componets is the way to find the problem , not guessing . Testing power an grounds . Voltage Drop Testing the Charging System Plus this charging system is computer controlled .Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model , engine size . Under system click on engine , subsystem click charging system .
Mar 30, 2017 | 2003 Dodge Caravan
Ipod will fully charge but only lasts a short time. whats wrong?
My little brother gave me his ipod shuffle for the same reason, saying the battery was dying and would only play for half an hour after a full night's charge. However, I went ahead and gave it a shot anyway and it always lasts for several hours (long enough that it's never died, so I don't know an actual time).
Anyway, it turned out to be a usb hardware problem. His old computer wasn't built to charge via usb, so the ipod would take what little it could and flop five songs later. I don't know what kind of hardware you're running, but perhaps you could try plugging it into a different computer and seeing if that chnges things?
I would also recommend looking into wall chargers, if that is the case. Otherwise the convenience factor kinda goes out the window.
DigitalGrampa@Gmail.com
Mar 28, 2009 | Apple iPod nano
Battery goes dead
Hi and welcome to FixYa,
Your post/description indicates two possibilities:
  • faulty the voltage regulator (most likely);
  • loose/corroded connectors (likely);
  • faulty alternator/stator (least likely).
Depending on the country of manufacture and/or the country of intended use, the voltage regulator would look something like the image below.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 22, 2008 | Yamaha G5 Motorcycles
GPX MW8847DT MP3 Player Logo
106 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
